SNMP Driver
The SNMP driver can be used to communicate with any device that uses the Simple Network Management Protocol (versions 1, 2c or 3).
SNMP data types influence your selection of I/O tag:
SNMP supports 12 data types. These are passed directly to the I/O tag, where further processing may be required.
- SNMP data types: Integer32, Unsigned32, Gauge32, Counter32, Counter64 and TimeTicks can be used with numeric tag types.
- SNMP data types: Integer(Enumerated), Octet String, Object Identifier, IpAddress, Opaque and Bits should be read in with a String I/O tag, with additional processing done using a Calculation tag as required.
SNMP drivers will commonly connect to UDP on port number 161 or 162, although variations may be found.
VTScada supports only ASCII-encoded MIB files.
Reference Notes:
I/O tags that are configured to use an SNMP driver will have an address selection feature. A button labeled "MIB" (management information base) will be added beside the Address field of the I/O tab. Clicking this will open an SNMP Address Select window (Address Assist / Address Select), from which you can choose the correct Object Identifier (OID) address.
The SNMP driver requires more configuration than other drivers. You will need to obtain the MIB library for your device from the manufacturer and you will need to tell VTScada where to find this information. See SNMP Addressing for details and configuration steps.
SNMP v3 Security
SNMP Driver properties, Communications tab
Use the Communications tab to select the port through which this driver will communicate as well as options for handling communication errors. In addition to the port parameters, this tab provides a location for you to specify the name of the SNMP group to which this driver instance will belong.
Port
Use the tag browser button to select the TCP/IP or UDP port tag to which the remote equipment is attached. The X button can use used to clear the current selection.
Maximum PDU Length (Bytes)
Use to specify the maximum length, as measured in bytes, of the Protocol Data Unit. This value need only be changed from the default if a different value is required by the equipment with which you will be communicating.
SNMP Group
The name of a VTScada RPC service to which this driver instance will belong. Alternate RPC services need only be created if your application uses multiple servers on separate sub-nets. In most applications you should leave the default value for this field.
Time-Out Limit
In the event that a connection cannot be made, sets the number of seconds until another attempt will be made.
Retries
Hold
Store Last Output Values
Enable Auto Rewrite
SNMP Driver properties, Agent tab
Provides configuration options related to the SNMP device with which this driver will communicate.
Format for SNMP 1 and 2c.
SNMP Version
Select the simple network messaging protocol version that the agent is using. Supported versions include 1, 2c and 3. Defaults to 1. Selecting version 3 will cause the available configuration parameters to change as shown
(v1 & v2c) Read Community String
Used for authentication of the device. The default value of "public" should have been changed on the device in the interest of improved security.
(v1 & v2c) Read/Write Community String
Similar to the Read Community String, this value is used to authenticate an SNMP device that will be used to both read and write information. Like the former, this value should be changed on the device from the default of "public".
(v3) Username
The name required for authentication.
(v3) Context Name
A context is a collection of information accessible by an SNMP entity. A SNMP Engine may contain one or more contexts, where the default context has an empty name. Information is not constrained to a single SNMP Engine ID or context. The same information can be available via different means. A context is used to define information subsets. For example, an SNMP Engine exposed to this driver might contain multiple components, each of which implements MIB items that may have conflicting OID info. The concept of a context was introduced to avoid this ambiguity. For simple devices the default context is sufficient.
SNMP Driver properties, Traps tab
In general, it is recommended that the Allow Traps option be disabled unless explicitly required.
Used to specify the port on which the driver will listen for unsolicited (Trap) messages. The intended purpose of Traps in SNMP is to notify the network management service so that it can investigate as required. They are not intended to set data because doing so represents a weak point in security (although, many devices use Traps to do exactly that). Traps typically contain messages such as a timestamp and an event OID such as a device restart.
The port number defaults to 162. Should not match the local or the remote port number.
You may set the port number to zero (0) to prevent the SNMP driver from accessing the port. This may be useful in the case that the driver should not open a port or receive traps.
The following notes are for SNMP version 3 only:
Additional configuration options, within the Trap Data block will be enabled when SNMP v3 is in use.
When filtering for a specific SNMP user, check that the minimum security level is set as required. Note that the user/security-level/context setup on the Agent tab is for commands (Get/Set/GetBulk) and has no effect on traps.
Security levels available when SNMP v3 is in use include:
- Accept traps with no security
- Only accept authenticated traps.
- Only accept authenticated and encrypted traps.
SNMP Driver properties, Informs tab
Set the credentials required to allow incoming Informs messages.
The authentication password field is enabled only when the security level is set to at least Authentication Only. The Privacy Password field is enabled only when the security level is set to Authentication and Encryption.
Security levels are set within the Agent tab.
The following widgets are available to display information about your application’s SNMP driver tags:
