Equipment / Status Color Indicator
Used by: I/O and Calculations, Alarm, Alarm Status, Analog Control, Analog Input, Analog Output, Analog Status, Calculation, Counter, Deadband, Digital Control, Digital Input, Digital Control, Digital Status, Function, History Statistics, Modem, Network Status, Pump Status, Rate of Change, Roster, Selector Switch, Serial Port, SMS Appliance, SQL Logger, TCP/IP Port, Totalizer, Trigger, UDP/IP Port,
Status color indicators can be found in the folders Equipment, Indicators >> Basic, and High Performance. These are images of equipment or ISA symbols that take their color from a Style Settings tag. You can choose whether the indicator should use the style for Digitals, High Performance, or an Equipment type.
The properties dialog for a Status Color Indicator widget:
Style
Optionally, select a Style Settings tag to control the colors shown by the light, in response to the linked tag's value and alarm state. See: Style Settings Tags
For Digital and Discrete I/O tags, use the following guide:
* If the widget has the option, Use High Performance Colors and that is selected, then those colors are used for 1 and 0 (On and Off).
* Otherwise if the linked tag has an Equipment Type and the Style has a definition for that type, then those colors and labels are used.
* Otherwise (at least for Digitals), the colors for the data type are used.
Image Select
Image Adjust
Image Clear
Equipment
High Performance
Indicators\Basic Indicators\
