Indicator Light Widget
Used by: I/O and Calculations, Alarm, Alarm Status, Analog Control, Analog Input, Analog Output, Analog Status, Calculation, Counter, Deadband Control, Digital Input, Digital Status, Digital Output, Digital Control, Function, History Statistics, Modem, Network Status, Pump Status, Rate of Change, Roster, Selector Switch, Serial Port, SMS Appliance, SQL Logger, TCP/IP Port, Totalizer, Trigger, UDP/IP Port.
Indicator Lights can take many forms. Each form is composed of a light and a frame. You can select different lights and frames for each indicator that you have drawn, mixing and matching the pieces.
The properties dialog for an Indicator Light:
Style
See:Style Settings Tags
Light Image
Select an image that will change color according to the style setting. Must be a gray scale image. Light images and lens images that are designed to work together will have matching names in the Lights folder of images palette.
Image Select
Image Adjust
Image Clear
Lens Image
Select an image that will frame the light, and provide a semi-opaque lens effect.
Indicators\Basic Indicators\
