The CalAmp diagnostic driver type enables users to read statistics from any given Integra-TR, Integra-H, Viper SC or Phantom II radio.
Reference Notes:
This driver was known as the Dataradio Diagnostic driver in earlier versions of VTScada.
These tags are required only in applications where you wish to gather data about a CalAmp unit.
For example, a common arrangement might be a CalAmp unit connected to your PC, and a secondary CalAmp unit connected to an RTU or PLC at a remote location. to collect data from the RTU or PLC, your VTScada application can use an appropriate communication driver tag such as Allen-Bradley or Modicon. If you wish to gather data about either CalAmp units in such a scenario (e.g. the temperature of the CalAmp unit), your application will require a CalAmp diagnostic driver tag.
In the unusual event that you have multiple devices attempting to use the same channel at the same time across multiple ports, you might consider adding Comm Link Sequencer Tags to serialize requests.
Comm Link Sequencer Tags - Serialize requests for the same communication channel across ports.
CalAmp Diagnostic Driver properties ID tab
When editing any textual parameter (description, area, engineering units...) always work in the phrase editor. Any  changes made directly to the textual parameter will result in a new phrase being created rather than the existing phrase being changed.
Server List
CalAmp Diagnostic Driver properties Type tab
The Type tab of the CalAmp diagnostic driver tag properties folder is used to select the type of CalAmp unit that this tag is to represent. The choices, as shown include:
- Integra-TR
- Integra-H
- Viper SC
- Phantom II
CalAmp Diagnostic Driver properties Serial tab
The Serial tab of the CalAmp diagnostic driver tag properties folder is used to select the port to which the CalAmp unit associated with this tag is connected.
The port on the Data Radio unit, from which VTScada collects diagnostic information, is a true RS-232 serial port. To connect to this port with VTScada, you can use one of several different hardware solutions:
- Serial port cable connected directly.
For this case, configure and select a Serial Port tag.
- Stand alone serial modem connected to the serial port on the radio.
VTScada has its own modem that is used to dial up the modem connected to the radio. For this option, configure and select a serial port that is using a modem.
- Ethernet terminal server connected to the serial port on the radio.
VTScada is connected to the same network as the terminal server and can connect to it with either a TCP/IP or UDP/IP port tag
- RJ-45 Ethernet port on the radio (Viper SC and Phantom II radios only).
Any VTScada port tag may be used, but it must match the hardware connection to the radio.
 CalAmp Diagnostic Driver Tag Widgets
                                            The following widgets are available to display information about your application’s CalAmp diagnostic driver tags:
