Comm Link Sequencer tags may be added when your application includes several device drivers that must share the same communication channel and that are themselves unable to determine when the channel is free. Newer radio devices that rely on a TCP/IP or UDP/IP port are particularly likely to experience this problem. This tag will automatically serialize access to the communication channel.
Use the Comm Link Sequencer tag only if you are experiencing communication problems that can be attributed directly to multiple devices attempting to use the same channel at the same time. If device access does not need to be serialized, then doing so will slow communication.
The Comm Link Sequencer is not required when multiple device drivers share the same port. Access to a single port is always serialized. The Comm Link Sequencer extends his sequencing across multiple port tags.
No configuration is required beyond the creation of a Comm Link Sequencer tag as a parent (or ancestor) of the port tags that will use it.
You can monitor this tag by drawing it on any page. The value will match the number of pending requests.
This tag is not logged. In the rare event that you need to view a history of this tag in the HDV, use TempLoggerEnable.
 Comm Link Sequencer properties ID tab
When editing any textual parameter (description, area, engineering units...) always work in the phrase editor. Any  changes made directly to the textual parameter will result in a new phrase being created rather than the existing phrase being changed.
 Comm Link Sequencer Tag Widgets
                                            The following widgets are available to display information about your application’s Analog Input tags:
