Draw Text Widget
Used by: I/O and Calculations, Alarm Status, Analog Input, Analog Output, Analog Status, Analog Control, Calculation, Comm Link Sequencer, Counter, Deadband Control, History Statistics, Linear Legend, Rate of Change, Selector Switch, Totalizer, SQL Logger.
The Draw Text widget is used to display the current value of any of a tag as text. Units (if any) will not be displayed and numeric values will display either 0 or 8 decimal points with no option for user-configuration. If you require just one decimal points of accuracy, or if you would like to display the engineering units that the value represents, then the Numeric Value Widget will be a better choice.
The properties dialog for the Draw Text object:
Font
Horizontal Alignment
Sets the position of the text within the display area. You may select left-aligned, right-aligned or centered. To align the display area itself with other elements on the page, see: Alignment and Positioning Tools.
Type of Border
Examples of the three border types are shown at the beginning of this topic.
Colors (Text and Background)
You can also set the background color against which the text will be displayed.
Basic Components\Text\
