Secure Your Application
Newly created applications run in an unsecured state until you decide that the time has come to secure them. When you first open the security dialogs, you must choose to secure the system and then create at least one account that you will use for managing it. From that moment on, all users (including you) must sign into the application to make any configuration changes.
After the application is secured, configuration is no longer available without signing in.
You can manage user accounts with VTScada or Windows or both.
  • If using VTScada authentication and authorization, all accounts and security privileges are managed within VTScada. The SCADA manager has full control over all aspects of each account.
  • If using Windows authentication, VTScada privileges are assigned only to roles, which are then associated with Windows groups. The Domain Administrator has control over creating and managing accounts, including which accounts are associated with which VTScada roles. The VTScada manager controls roles and the privilege set associated with each role.
If you enable outside connections to your SCADA system using the VTScada Thin Client Server to allow remote connections, then you must also take steps to secure the communication between the remote site and your server. This is done by implementing a Virtual Private Network (VPN) or by purchasing and installing an SSL Certificate. Refer to Internet Security (SSL, TLS, X509).
The VTScada Internet Client (VIC), Anywhere Client, and the Mobile Browser Client (MIC) cannot access any application that is running in an unsecured state. Only a secured application will allow remote access and alarm acknowledgment via phone, email or text message, and then only to authorized accounts.
Similarly, you must secure your application before you can make use of the ODBC interface to query the VTScada database, or use the VTScada Excel Add-in. Note that the Excel Add-in cannot connect to a VTScada server that is not protected by SSL.
"SSL" is the acronym for the Secure Sockets Layer security protocol. SSL is an older technology, but the term has become the de facto name for Internet security. VTScada uses the more modern Transport Layer Security (TLS) protocol (although, for the sake of compatibility with older Windows operating systems, it can use SSL.)
While the term "SSL Certificate" is in common use, "X509 Certificate" is the correct term.
Privileges built into VTScada restrict access to VTScada features such as access to the built-in pages. To control access to your own pages and to operator controls that you build, you must create new privileges and apply them to the features that are to have restricted access. By default, all operator controls are protected from use when no-one is logged on, but most sites prefer to create a set of privileges so that they can control the access that each operator has.
Roles should be used to simplify account management, whether you are using VTScada or Windows authentication. A role is a named set of privileges and can be thought of as a job description. Changes made to a role's privilege set are automatically applied to the operators who have been assigned to that role. You can assign several roles to any account and one role can include another.
Two factor authentication? Available only to those using OpenID Connect Authentication to Connect Using the Anywhere Client.
A set of functions and properties within the security manager are available to programmers, allowing them to check who is signed in or what privileges are in effect for the signed in user. With this information they can design their custom modules to enable or disable features for that user.
Terms:
General Privilege
A permission to access or use one of the VTScada system tools. Access to the Idea Studio, the ability to acknowledge alarms, etc., are controlled by general privileges.
Custom Privilege
A permission created by a VTScada developer. You can apply custom privileges to pages and to output tags to restrict access to these user-created items.
Alternate ID
A numeric identification associated with an account. Used to verify an account when signing in via the Alarm Notification System, or a proximity card reader. There can be only one alternate ID associated with any account.
Security Role
A named set of permissions. You can assign one or more security roles a user account to grant common privileges to people with similar job descriptions.
Security Rule
Refers to conditionally-granted privileges. You can limit the scope of a custom privilege so that it applies only to certain tags, or of any privilege be in effect only when a user is signed in at a named workstation.
Security Menu
Where you will find tools to open the various security-related dialogs. Available in the Application Configuration dialog in the Edit Security tab, and (after signing in) from the button at the top-right of the VTScada application window, labeled with your account name.
Disable Windows Controls (Kiosk Installations)
VTScada cannot disable access to Windows controls (file menu, close, minimize...) or keyboard commands (Ctrl-Esc, Alt-Tab, and Ctrl-Alt-Delete). This could be accomplished with a Windows logon script. Refer to:
https://docs.microsoft.com/en-us/windows/configuration/kiosk-single-app
