String I/O Tags
Counted towards your tag license limit.
This is a legacy tag type. You are advised to use the I/O and Calculations Tag instead.
Use this legacy type only if you are certain that it contains unique features that are absolutely necessary to your work.
String I/O tags are used to read or write text values. They are designed to be simple to configure and straight-forward to use.
If you wish to use a String I/O tag for local storage of values, you must clear the I/O device field. Doing so will allow the String I/O tag to retain values without an attached driver.
Retained or Persisted values
Analog Control and Analog Output tags will both retain their last written value across application restarts. Use these tags when there is a need for a value to persist.
String I/O tags with output enabled, and with no driver ("No tag selected" rather than the default, "[*Driver] None found") will retain their last written value across application restarts.
The Digital Control and Digital Output tags do not have a similar feature, but an analog tag can be used in their place, writing a zero or a one. If the intent is to write a clear zero or one with an analog tag, both the scaled and unscaled range should be adjusted for a minimum value of zero and a maximum value of one, so that scaling does not adjust the values.
Use this tab to specify the device driver and the address where values are to be read or written.
If output strings are to have a minimum length, you can choose to add spaces, further specifying whether those spaces should be added at the beginning, the end, or equally to either side of the string.
I/O Device
Scan Interval
Provide the frequency, measured in seconds, at which the I/O device should be scanned for new data. Reduce system load by setting this as high as possible, as appropriate for the equipment being monitored. If the I/O Device is a Polling driver, which provides its own scan interval, then this field will not accept data.
Manual Data
Sets a constant value that will be used instead of live data. Use when testing a new tag if you need to check behavior when a value is outside the normal operating range. Tags that have manual data are marked by a flashing exclamation mark within any linked widgets. Logged values are marked with an exclamation. Always reset this to blank after testing.
Enable Output
If selected, this input tag may also be used to write data to the specified address of the communication driver. A Security Privilege may be set in the Quality tab to restrict access to this feature.
Values that are to be written may be padded with blank spaces to achieve a minimum length
Pad With Spaces
Enabled only when output is enabled. Selecting this box is the first step in specifying a minimum number of characters to be sent in each write operation.
Minimum Length
Enabled only when Pad With Spaces has been selected. Use this to specify the minimum number of characters to be sent in each write operation.
Justify
Enabled only when Pad With Spaces has been selected. Extra spaces, added to meet the minimum string length, may be added at the beginning of the string (Right Justify), at the end of the string (Left Justify) or equally at either end of the string (Center).
String I/O properties: Merit tab
Privilege
String I/O properties: Display tab
Use this tab to set tag's position in the I/O lists of a Site Details page, relative to other String I/O tabs.
String I/O properties: Historian tab
Historian
Enable Logging
If values should be logged only while certain conditions are true, you can tie the Enable Logging option to any tag or expression that will change from zero (logging disabled) to non-zero (usually 1; logging enabled).
The following widgets are available to display information about, or allow data entry for, your application’s String I/O tags:
