Tags and I/O
                                        New to VTScada? This topic is also covered in the tutorial: Tag Browser (Tutorial)
Tags are the software representation of the parts of a physical system. A tag might represent the status of a pump, the level of a tank, a control switch to open a valve, etc. Tags also represent the connections to your hardware, both physical (TCP/IP or Serial) and software (the choice of driver). Further, tags are used to hold certain configuration settings including fonts, default colors for widgets, alarm priority characteristics and more.
In short, tags represent "things". Any things.
Points? A tag is a point and a point is a tag. VTScada uses the word "tag" more often (that's what the T in VTScada is for, after all) but "point" was used first, and you'll still see it from time to time.
The Tag Browser is the main tool for creating, modifying and deleting tags. It is also possible to export tags to a spreadsheet or database, then import changes back to the application. This is less user-friendly and is not advised for creating new tag hierarchies, but can save time when creating or updating many similar tags in existing hierarchies.
Organize your tags into a hierarchy so that it is easy to see which tags relate to which components in the system. Besides making it easier  to find a given tag, this system makes it easy to expand the application by copying entire structures. While any tag could serve as the starting point to each hierarchy, the best choice is a Context tag, which provides context to a group of related tags.
When editing any textual parameter (description, area, engineering units...) always work in the phrase editor. Any  changes made directly to the textual parameter will result in a new phrase being created rather than the existing phrase being changed.
