Subordinate Application Tags
Provides monitoring and access to all tags in a selected subordinate application. The application holding the Subordinate Application tag is referred to as a Master application.
All the tags in the selected subordinate application will be visible as children of the Subordinate Application tag, so long as all user-defined types defined in the subordinate application are also defined in the master application. If the master application and subordinate application are not built on the same layer where that custom type is defined, then you must copy the definition from the subordinate application to the master application.
A master application can have several subordinate application tags, but each must link to a separate application. If two link to the same application, only one will function at a time.
You must have a security account with the Manager privilege in the subordinate application before you can configure a subordinate application tag to link to that application. You will be prompted for a username and password.
Note to advanced developers: If writing an expression that involves a subordinate application, the value of a SubordinateApplication tag is TRUE when the subordinate application is running and synchronized with the master application, and FALSE when it is not.
Subordinate Application tags are excluded from tag exports.
Master & Subordinate Applications - A full description of master and subordinate applications.
Copy Types to Other Applications - Ensure that types defined in the subordinate are available in the master.
Subordinate Application tag properties: Settings Tab
The Settings tab holds a drop-down list, from which you can select the subordinate application.
Authentication to an account possessing the Manager privilege is required if the subordinate application is secured. Trihedral strongly recommends that all applications be secured.
Immediately upon selecting the subordinate application, you will be prompted to authenticate with that application.
Enter the user name and password for an account in the subordinate application that possesses the Manager privilege.
The following widgets are available to display information about your application’s Subordinate Application tags.
Alarms in the subordinate application will not propagate to the master application's site icon widgets.
