BSAP Driver Tags
The BSAP driver enables communications between VTScada and RTUs using the BSAP communication protocol.
The following property settings hold additional configuration parameters for your BSAP driver:
BSAPRestartTime - BSAP Driver restart time. Defaults to 15 seconds.
BSAPRBEScanRate - BSAP Driver RBE scan rate. Defaults to 300 seconds.
BSAPRBEScanSlice - BSAP Driver RBE scan slice. Defaults to 1.
BSAPRBEMsgFrmt - BSAP Driver RBE message format. Defaults to 1.
BSAPRBEStopXmit - BSAP Driver RBE Stop Transmit setting. Defaults to 0.
BSAPRBEWaitMsgTO - BSAP Driver RBE wait message timeout. Defaults to 300 seconds.
BSAPMaxFrameSize - BSAP Driver IBP maximum frame size. Defaults to 1000 bytes.
BSAPMsgSendTimeOut - BSAP Driver IBP message send timeout. Defaults to 0.5 seconds.
BSAPUnAckMsgCount - BSAP Driver IBP unacknowledged message count. Defaults to 15.
BSAPTimeSyncTimeOut - BSAP Driver time synch timeout. Defaults to 60 seconds.
BSAPUDPRetryDelay - BSAP Driver UDP retry delay. Defaults to 10 seconds.
Local Address
Local address of level 0 RTU (1 - 127).
Global Address
Global address of the level 1 - 7 RTU - must be invalid for level 0 RTU
Time Sync Port Number
Time synchronization UDP port number.
Time Sync Frequency
Time synchronization frequency in seconds.
RTU Polling Time
Period between subsequent polls by the BSAP network manager of the level 0 RTU which may have other reachable RTU's via radio or other means. Note that the Network Manager communicates on a given port and all RTU's using that port use the same network Manager. Therefore if an RTU tag changes this value it will be updated in all the RTU drivers associated with that port. This is so that on a restart of the Network Manager, which can be started by a different driver tag, the driver would see the changed value.
Download Security
Used to attach a security privilege to the download functions on the driver. The user must have this privilege in their VTScada account to perform download functions.
Driver Service Name
The RPC service name to be used by this driver. Leave blank if unsure of using the same service as all other BSAP drivers.
Connection Time Limit
Connection timeout for the network manager making a connection to a level 0 RTU. Note that the Network Manager communicates on a given port and all RTU's using that port use the same network Manager. Therefore if an RTU tag changes this value it will be updated in all the RTU drivers associated with that port. This is so that on a restart of the Network Manager, which can be started by a different driver tag, the driver would see the changed value.
RTS Key Off Delay
Key off delay for radio operation.
Local RTU Time Limit
Response timeout limit for level 0 RTU.
Data Read Time Limit
Read response time out limit for RTU response.
RBE Time Limit
Timeout limit to wait for a response for status request message from the RBE manager task in the RTU
Retries
Number of driver retries on failure before an error is logged. Note that the Network Manager communicates on a given port and all RTU's using that port use the same network Manager. Therefore if an RTU tag changes this value it will be updated in all the RTU drivers associated with that port. This is so that on a restart of the Network Manager, which can be started by a different driver tag, the driver would see the changed value.
Hold
If selected driver data will remain at the last known value on communications failure. If unselected data will be blanked or made Invalid.
The configuration of a BSAP driver's node routing table:
Global Address Calculation
A Network 3000 node determines its global address and its UP/DOWN mask as follows.
The calculation uses the node's local address, level number, level shift count, level bit mask and the global address of the node's local master. The NRT
Node Routing Table trickles down from the network master to all nodes on the net-work. A master passes an exact copy of its NRT to each of its slaves. Each slave then uses the procedure described following to construct its NRT which it then passes to each of its slaves. Both the NRT global ad-dress field and UP/DOWN mask starts off as zero (i.e. the network master's global address and UP/DOWN mask are by definition zero). As the NRT is distributed each node determines its global address and UP/DOWN mask and fills in the appropriate field in the NRT. Therefore the global address of a node is the concatenation of the local addresses of all previous local masters that the NRT has traveled to, from the network master to that node.
The following steps illustrate the calculation of a node's global address.
- Increment level number
- Node's local address shifted left Level_Shift_Count times
- Result from step 1 is OR'ed in with the current NRT Global address (i.e. local master's global address)
- Result from step 2 is now placed in the NRT Global address field (i.e. now it is the node's global address)
The following steps illustrate the calculation of a node's UP/DOWN mask.
- Node's Level_Bit_Mask shifted left Level_Shift_Count times
- Result from step 1 is OR'ed in with the current NRT UP/DOWN mask (i.e. local master's UP/DOWN mask).
- Result from step 2 is now placed in the NRT UP/DOWN mask field (i.e. now it is the node's UP/DOWN mask).
The following widgets are available to display information about your BSAP driver tags:
BSAP Driver Addressing
The I/O tag addressing consists of a text-based tag name with a prefix as follows:
I/O Reads:
| I/O Read Prefix | Function |
| RDB | Read Database |
| PTP | Point to Point |
| RBE | Report by Exception |
I/O Writes:
| I/O Write Prefix | Function |
| DIG | Digital I/O Tags |
| ANA | Analog I/O Tags |
| STR | String I/O Tags |
