Slay a Module Instance
The Source Debugger enables you to slay a module instance. This can be especially useful if you have created a launched module that contains an IF 1 condition.
To slay a module instance:
  1. Use the Module Tree Window to select the module for which you wish to slay an instance.
  2. If there is more than one running instance, use the spin box at the upper right of the Module Content Window to scroll through the instance numbers. (Alternatively, by selecting a specific module instance from the scope or call tabs of the module window, you can go directly to a specific instance.)
  3. Click the Slay button.
    A dialog will open and request confirmation that you wish to slay the selected module instance.
  4. Click the Yes button.
    The instance of the module you have selected will be slain.
