Call Progress and Error Codes
Some values may overlap with Modem Tag Return Values. Use care not to confuse the two.
Values greater than or equal to zero are progress codes, while values less than zero are errors.
Progress Codes
Code |
Description |
0 |
LineIdle Idle (no connection), waiting for call |
1 |
CallBegins Starting outbound call |
2 |
RingAnswered Incoming call answered, no connection yet |
3 |
DialToneOK Dial tone on outbound call |
4 |
DialingOut Dialing outbound call |
5 |
RemoteRinging Remote phone ringing on outbound call |
6 |
RemoteBusy Remote phone busy on outbound call |
7 |
CallConnected Connected (You should not see this value. A stream value is returned at this point) |
8 |
HandedOff Another application is handling the call |
9 |
IncomingCallRQ Incoming call detected |
10 |
TempProblem Temporary modem problem - hang up and retry |
11 |
IncomingCall Incoming call accepted |
Error Values
Value |
Error |
-1 |
NoModems No modems defined in the system |
-2 |
NoDialTone No dial tone detected on outbound call |
-3 |
RemoteBusyErr Remote phone busy on outbound call |
-4 |
NoAnswer No answer on outbound call |
-5 |
CallerHungUp Other end hung up an incoming call |
-6 |
ModemUnavail Modem unavailable |
-7 |
CallFailure Other call termination condition |
TAPI Errors
Errors equal to or less than -101 correspond to the Microsoft Telephony Interface (TAPI) errors, which are normally numbered from 1. Specific errors that may be encountered are:
Code |
TAPI error |
-101 |
TAPI error code 1 (LINEERR_ALLOCATED) - the serial port is in exclusive use by some other process. |
-112 |
TAPI error code 12 (LINEERR_INCOMPATIBLEAPIVERSION) - the system does not have the required version of telephony support (TAPI 2.0 required). |
-115 |
TAPI error code 15 (LINEERR_INUSE) - the line device is in use and cannot currently be configured, nor can it allow a party to be added or a call to be answered, placed, or transferred. |
-147 |
TAPI error code 47 (LINEERR_INVALMEDIAMODE) - the requested media mode could not be accommodated (e.g. voice call request on a non-voice modem). |
-167 |
TAPI error code 67 (LINEERR_NODEVICE) - the specified device identifier, which was previously valid, is no longer accepted because the associated device has been removed from the system since TAPI was last initialized. Alternately, the line device has no associated device for the given device class. |
-168 |
TAPI error code 68 (LINEERR_NODRIVER) - either TAPIAddr.dll could not be located, or the telephone service provider for the specified device found that one of its components is missing or corrupt in a way that was not detected at initialization time. Use the Telephony Control Panel to correct the problem. |
-169 |
TAPI error code 69 (LINEERR_NOMEM) - insufficient memory to perform the operation, or unable to lock memory. |
-175 |
TAPI error code 75 (LINEERR_RESOURCEUNAVAIL) - insufficient resources to complete the operation (e.g. a line cannot be opened due to a dynamic resource over-commitment). Also occurs where a modem is being used by a non-TAPI application. |
The full list of possible TAPI error codes:
Error |
Code |
Error |
Code |
ALLOCATED |
101 |
INVALMEDIAMODE |
147 |
BADDEVICEID |
102 |
INVALMESSAGEID |
148 |
BEARERMODEUNAVAIL |
103 |
INVALPARAM |
150 |
CALLUNAVAIL |
105 |
INVALPARKID |
151 |
COMPLETIONOVERRUN |
106 |
INVALPARKMODE |
152 |
CONFERENCEFULL |
107 |
INVALPOINTER |
153 |
DIALBILLING |
108 |
INVALPRIVSELECT |
154 |
DIALDIALTONE |
109 |
INVALRATE |
155 |
DIALPROMPT |
110 |
INVALREQUESTMODE |
156 |
DIALQUIET |
111 |
INVALTERMINALID |
157 |
INCOMPATIBLEAPIVERSION |
112 |
INVALTERMINALMODE |
158 |
INCOMPATIBLEEXTVERSION |
113 |
INVALTIMEOUT |
159 |
INIFILECORRUPT |
114 |
INVALTONE |
160 |
INUSE |
115 |
INVALTONELIST |
161 |
INVALADDRESS |
116 |
INVALTONEMODE |
162 |
INVALADDRESSID |
117 |
INVALTRANSFERMODE |
163 |
INVALADDRESSMODE |
118 |
LINEMAPPERFAILED |
164 |
INVALADDRESSSTATE |
119 |
NOCONFERENCE |
165 |
INVALAPPHANDLE |
120 |
NODEVICE |
166 |
INVALAPPNAME |
121 |
NODRIVER |
167 |
INVALBEARERMODE |
122 |
NOMEM |
168 |
INVALCALLCOMPLMODE |
123 |
NOREQUEST |
169 |
INVALCALLHANDLE |
124 |
NOTOWNER |
170 |
INVALCALLPARAMS |
125 |
NOTREGISTERED |
171 |
INVALCALLPRIVILEGE |
126 |
OPERATIONFAILED |
172 |
INVALCALLSELECT |
127 |
OPERATIONUNAVAIL |
173 |
INVALCALLSTATE |
128 |
RATEUNAVAIL |
174 |
INVALCALLSTATELIST |
129 |
RESOURCEUNAVAIL |
175 |
INVALCARD |
130 |
REQUESTOVERRUN |
176 |
INVALCOMPLETIONID |
131 |
STRUCTURETOOSMALL |
177 |
INVALCONFCALLHANDLE |
132 |
TARGETNOTFOUND |
178 |
INVALCONSULTCALLHANDLE |
133 |
TARGETSELF |
179 |
INVALCOUNTRYCODE |
134 |
UNINITIALIZED |
180 |
INVALDEVICECLASS |
135 |
USERUSERINFOTOOBIG |
181 |
INVALDEVICEHANDLE |
136 |
REINIT |
182 |
INVALDIALPARAMS |
137 |
ADDRESSBLOCKED |
183 |
INVALDIGITLIST |
138 |
BILLINGREJECTED |
184 |
INVALDIGITMODE |
139 |
INVALFEATURE |
185 |
INVALDIGITS |
140 |
NOMULTIPLEINSTANCE |
186 |
INVALEXTVERSION |
141 |
INVALAGENTID |
187 |
INVALGROUPID |
142 |
INVALAGENTGROUP |
188 |
INVALLINEHANDLE |
143 |
INVALPASSWORD |
189 |
INVALLINESTATE |
144 |
INVALAGENTSTATE |
190 |
INVALLOCATION |
145 |
INVALAGENTACTIVITY |
191 |
INVALMEDIALIST |
146 |
DIALVOICEDETECT |
192 |
ALLOCATED |
101 |
INVALMEDIAMODE |
147 |
