SetCertificateProperty
| Description: | Sets a modifiable property on a stored certificate. |
| Returns: | Integer. Zero for success or a system error code. |
Usage: ![]() |
Script Only. |
| Function Groups: | Certificates |
| Related to: |
AddCertificate | CheckCertificateChain | FindCertificate | GetCertificateInfo | ListCertificates | MakeSelfSignedCertificate | RemoveCertificate |
Format: ![]() |
SetCertificateProperty(MachineStore, StoreName, Thumbprint, Property, PropertyValue) |
| Parameters: |
MachineStore |
| Required Boolean. If TRUE (non-zero) attempts to find the certificate in a store in the Local Computer certificate hive. If FALSE (zero) attempts to find a certificate in a store in the Current User certificate hive. |
| StoreName |
| Required text. The name of the store in which to search for the certificate. |
| Thumbprint |
| Required. A binary buffer holding the SHA1 thumbprint of the certificate to locate. |
| Property |
| Required integer. The identifier of a property to set. Properties are identified by numbers. |
| PropertyValue |
| Required text. The text to which the property will be set. |
| Comments |
This statement allows you to set the following properties:
Once a certificate has been created, the only properties that can be set are those that do not comprise the signed part of the certificate. |
Example:
SetCertificateProperty(FALSE, "My", NewCertThumbprint, 0, "North Point");
This sets the certificate identified by NewCertThumbprint in the current user’s Personal store to have the friendly name "North Point". The intent is to create an alternative human-friendly means of certificate identification.
