Reset Button Widget
The Reset Button widget is used to create a button in your application that will reset a Totalizer tag or a Counter tag to zero.
Button Label
Enter the text you want to display. Labels should be clear but short, as the length of the label determines the size of the button.
Confirmation Dialog
Select this option if you want users to be prompted to confirm that they meant to press the reset button. Defaults to selected.
