Make Active Widget
Used in association with the Alarm Notification System, the Make Active tag widget will create a button that can be clicked to select the associated Roster tag as the active roster. This is used to select who will be contacted by the call-out system in the event that an alarm has been triggered and has gone unacknowledged for a defined period of time.
The properties dialog for the Make Active widget:
Button Label
Enter the text you want to display. Labels should be clear but short, as the length of the label determines the size of the button.
Basic Components\Specialty\Roster Control\
