Data Age Widget
Used by: Data Flow RTU, Polling Driver.
The Data Age tag widget is used to display the time of the most recent poll of an RTU in hours, minutes, and seconds.
An example of a configured properties dialog for the Data Age widget:
Font
Select one of the font tags (or parameter linked to a font tag) that you with to use to display the text. The display will use the default system font if you do not select a font tag.
The parameters button is enabled only if the tag is drawn on a page that includes a font parameter or if the tag is part of a widget and the associated widget editor is open.
Type of Border
Select the type of border you would like to display the data age within. This can be one of three choices, as illustrated:
Text
Opens the Select Color Dialog from which you can choose the color of the text.
Background
Opens the Select Color Dialog from which you can choose the color of the background.
Analytics\Communications\Polling\
Analytics\Diagnostics\
