Function Reference
Ack | Acknowledge an alarm. |
AckAllAlarms | Acknowledge all unacknowledged alarms available to the current user. |
AckAllAlarmsPlusDlg | Acknowledge all unacknowledged alarms available to the current user after confirmation |
AdHocAlarm | Evaluates an ad hoc alarm |
Commission | (Alarm Manager module) Commission the alarm by adding it to the Configured list. |
Decommission | (Alarm Manager module) Decommission an alarm by name. |
EvaluateAlarm | (Alarm Manager module) Passes a new value to an alarm, to be compared to the setpoint. |
GetAlarmConfiguration | (Alarm Manager module) Returns a copy of an alarm's configuration structure from the master alarm list, creating it if it does not already exist. |
GetAlarmList | (Alarm Manager module) Returns filtered lists of records from alarm databases. |
GetAlarmObject | (Alarm Manager module) Returns an alarm object value given an alarm name. |
GetAlarmStateStats | (Alarm Manager module) Returns a structure containing the cumulative alarm state statistics for the specified tag. |
GetAlarmStatus | (Alarm Manager module) Returns a reference to an alarm's status structure in the master database, providing access the alarm's current state without having to make additional function calls. |
GetContainerNumActive | Returns the number of active alarms within a hierarchy of tags. |
GetContainerNumUnacked | Returns the number of unacknowledged alarms within a hierarchy of tags. |
GetNameOfRecord | (Alarm Manager module) Given an alarm record, returns the tag name. |
(Alarm Manager module) Returns either the number of unacknowledged alarms or a Yes/No flag to indicate that the alarms exist. If realm-area filtering is in use, results will be limited to the operator's realm. |
GetUserNameOfRecord | (Alarm Manager module) Given an alarm record, returns the user name associated with the transaction. |
(Alarm Manager module) Will indicate if an alarm is currently active. GetAlarmStatus should be used in new code. |
(Alarm Manager module) Will indicate if an alarm is currently disabled. GetAlarmStatus should be used in new code. |
IsShelved | (Alarm Manager module) Will indicate if an alarm is currently shelved. It can be used either as a subroutine or as a called function. |
(Alarm Manager module) Will indicate if an alarm is currently unacknowledged. GetAlarmStatus should be used in new code. |
(Alarm Manager module) This subroutine is used to turn off alarms sounds for all alarms, both current and future. |
(VTS Library) Draws a droplist of the currently available alarm priorities with an optional title or bevel or both. |
SetShelved | AlarmManager plug-in, that handles the shelving and unshelving of alarms. |
(Alarm Manager module) This subroutine will silence the current sounding alarm. |
The following alarm functions are deprecated or obsolete as of version 11.2 | |
Deprecated. (Alarm Manager module) Will acknowledge an alarm. |
Deprecated. (Alarm Manager module) Tells the Alarm Manager to activate an alarm. This subroutine will activate an alarm and signal it as unacknowledged. |
ActiveMonitor |
Obsolete. (Alarm Manager module) Starts the required actions for an active alarm. ActiveMonitor waits for an alarm to activate, then activates the Sounder and, (if enabled) calls AlarmManager to add the pop-up. |
AlarmSoundCheck |
Obsolete. (Alarm Manager module) Checks to see if an alarm sound can be played for the given alarm |
Deprecated. (Alarm Manager module) Tell the Alarm Manager to disable an alarm. Disable will also clear any active or unacknowledged state that might exist. |
DoAcknowledge |
Obsolete. (Alarm Manager module) This subroutine will do the actual work of acknowledging, while the Acknowledge subroutine is responsible for informing other computers in the network about the alarm acknowledgment. |
Deprecated (Alarm Manager module) Tell the Alarm Manager to enable an alarm. |
Deprecated. (Alarm Manager module) Tell the Alarm Manager when an alarm event occurs. This subroutine will cause an entry to be added to the log file without changing the alarm status. |
Deprecated. (Alarm Manager module) This subroutine will add the alarm object to a list. This is useful if a user-defined list has been created. |
Deprecated. (Alarm Manager module) This subroutine will remove the alarm object from a list. This is useful if a user-defined list has been added. |
Deprecated. (Alarm Manager module) Use this function to tell the Alarm Manager when an alarm clears. This subroutine will deactivate the alarm. It will not affect the unacknowledged status. |
Deprecated (Alarm Manager module) This subroutine will deactivate an alarm and signal it as unacknowledged. |
Deprecated. (Alarm Manager module) This subroutine will activate the alarm. However, it will not affect the unacknowledged status. |
Popup |
Deprecated. (Alarm Manager module) Causes an alarm pop-up dialog to display. |
Deprecated. (Alarm Manager module) Inform the Alarm Manager that a module instance may wish to generate alarms in the future. |
Deprecated. (Alarm Manager module) Use in preference to Enable to enable or disable alarms build into tags. |
ShelvedEvent | Obsolete. AlarmManager plug-in, called to record a shelved alarm event. |
StartSound |
Obsolete. (Alarm Manager module) This subroutine is used to start a sound for an alarm if alarm sound is enabled and the alarm priority is higher than currently sounding alarm. |
Deprecated (Alarm Manager module) The TransferFields subroutine will transfer the values for each field into the returned FieldValues array. The values are found in the scope passed in using the variable names found in the FieldNames array. |
Deprecated. (Alarm Manager module) Tell the Alarm Manager to when a trip alarm event occurs. This subroutine will signal an alarm as unacknowledged. |
Deprecated. (Alarm Manager module) Notify the Alarm Manager that an alarm has been removed. This will not generate an alarm, it just removes it from the list of all configured alarms. |
AdjustArray | Changes the array information for a variable. |
AMax | Array maximum. This function returns the maximum value in a sub-range of a numeric array. |
AMin | Array minimum. This function returns the minimum value in a sub-range of a numeric array. |
ArrayDimensions | Returns the number of dimensions in an array. |
ArrayOp1 | Performs a mathematical operation on an array with respect to a scalar value. |
ArrayOp2 | Performs a mathematical operation on an array with respect to another array. |
ArraySize | Returns the number of elements in an array dimension. |
ArrayStart | Returns the first element in an array dimension |
ArrayToBuff | Returns a buffer containing the numeric data from an array. |
ArrayToDictionary | Returns a dictionary if given an array of key names and a matching array of values. |
AValid | Returns the number of valid elements in an array sub-range. |
BuffToArray | Reads an array from a formatted buffer containing numerical data and returns the number of elements read. |
BuffToPointer | Converts a buffer of numeric data to array of pointers. This function reads from a formatted buffer containing numeric data, writes to locations specified by an array of pointers, and returns the number of elements read. |
Compress | Eliminate invalid array entries. |
DeleteArrayItem | Deletes an element from a single dimension dynamically allocated array and returns the modified array. |
Filter | Sets the value of one array element to invalid if the corresponding value in another array element is invalid. |
FiltHigh | Sets the values in an array sub-range that fall above a specified upper limit to a new value. |
FiltLow | Sets the values in an array sub-range that fall below a specified lower limit to a new value. |
InsertArrayItem | Insert Array Item. This function inserts an element into a dynamically allocated array and returns the modified array. |
LookUp | Looks up a value in an array and returns the index of the element containing that value. |
MakeArray | Create and initialize an array in one line of code. |
Mean | Returns the mean (average) of a portion of a numerical array. |
New | Allocates memory for an array from RAM and returns a pointer to that array. |
PointerToBuff | Returns a buffer containing the numeric data from the variables pointed at by each element of the array. |
ReadX | Reads numeric data from a text file into the elements of an array. |
ReadXY | Reads data points from a file into the elements of two arrays. |
SDev | Returns the statistical sample standard deviation for a subsection of an array. |
Sort | Allows the sorting of an array subsection according to the order of another array. |
SortArray | Sorts an array of arrays based upon the key information provided by the second parameter. |
Sum | Returns the arithmetic sum of all the valid array elements in a specified portion of a numeric array. |
TextSearch | Returns the array index of the first occurrence of the given text key in an alphabetically ordered array. |
Unpack | Unpacks a set of values from a stream into a single dimensional array or a set of variables referenced by object parameters, and returns the number of items unpacked. |
UnpackData | (RPC Manager Library) This method unpacks a stream into an array or set of module instance parameters. Subroutine call only. |
Variance | Returns the statistical sample variance for a subsection of an array. |
WatchArray | Watches an array and returns true if any of its elements types or values change. |
And | Returns the bit-wise AND of its two parameters as a 32-bit unsigned integer. |
Bit | Returns the on/off status of a bit in a number. |
Not | Returns the result of a 32 bit unsigned bitwise logical NOT operation. |
Ones | Returns the number of bits set in an integer number. |
Or | Performs a bit-wise OR operation and returns the result. |
SetBit | Sets or clears a specific bit in a value and returns the result. |
XOr | Returns the bitwise exclusive OR of its parameters. |
AddCertificate | Returns a structure of information about a supplied X.509 certificate. |
CheckCertificateChain | Checks the chain of trust of a certificate |
FindCertificate | Locates a certificate in a certificate store. |
GetCertificateInfo | Returns a structure of information about a supplied X.509 certificate. |
ListCertificates | Enumerates X.509 certificates in a certificate store resident on the local computer. |
MakeSelfSignedCertificate | Creates a new self-signed certificate. |
RemoveCertificate | Removes a certificate from a certificate store. |
SetCertificateProperty | Sets a modifiable property on a stored certificate. |
ClipboardGet | Returns the current contents of the system clipboard as a string. This function enables an application to perform text "paste" operations. |
ClipboardPut | Set the current contents of the system clipboard to a string. This function enables an application to perform text "copy" or "cut" operations. |
Blend | Returns an aRGB color value that is a given percentage between two specified colors. |
Brush | Returns a brush value. |
Cls | Clears the screen and sets its background color. |
ColorSelect | (System Library) Color Selection Tool. This module draws a color selection button and its accompanying display area. |
GetColorInfo | Returns the brush and pen information for a given graphic statement. |
GetSystemColor | Returns the colors for the user-configured Windows™ colors. |
PalStatus | Returns the current palette settings. |
PColorSelect | (VTS Library) Draws a button that opens a color selection dialog and an area that displays the currently selected color. |
Pen | Returns a pen value. |
PixelColor | Returns the color of a pixel in the window. |
ZColorChange | Changes one color within a region to another color. |
ActiveX | Instantiates an ActiveX object. An ActiveX object is treated as a COM client interface that requires a client window area in which to draw. |
COMClient | Instantiates COM objects that do not possess a user interface. |
COMEvent | Sets an event subroutine context for an existing COM client interface. |
COMStatus | Returns the last status information that occurred for a specified COM client interface. |
ActiveCode | ActiveCode returns the code value of the currently active statement in the given module instance. |
ActiveState | ActiveState returns the code value of the currently active state in the given module instance. |
ActiveWindow | ActiveWindow returns the object value of the root module instance in the current active window. |
AddModule | Adds a new module to an existing module and returns the value of the newly created module. |
AddOptional | Adds a new statement to an action script and returns its own error code. |
AddPageToApp (Obsolete) | Creates a new application page. |
AddParameter | Adds an existing variable as a module parameter and returns the number of parameters in the module. |
AddState | Adds a new state to an existing module and returns its state value. |
AddStatement | Adds a new statement to an existing state and returns its own error code. |
AddVariable | Adds a new variable to an existing module and returns its variable value. |
AdjustCode | Adjusts the offsets and sizes of items stored in the .RUN file within the document file. |
BuffToParm | Convert buffer of numeric data to parameters. This function reads module parameters from a formatted buffer containing numerical data and returns the number of data items read. |
Call | Starts an instance of the module specified by its first parameter. |
CalledInstances | Returns the object values of module instances that are called by a particular module. |
Caller | Takes a given object value for a module and returns the object value of the module by which it was called. |
CanEditDoc | Returns an indication as to whether the document for the given module can be edited. |
Cast | Takes a value and returns a different type of value, if possible. |
ChildDocs | Gets the module values for the root and all descendent modules that match the conditions defined by the second parameter. |
ClearModule | Deletes the contents (all variables and states) of a module without removing the module itself. |
ClearState | Deletes all of the statements in a state. |
Compile | Compiles text and creates a new function. The type of return value is determined by its input parameters. |
ConstCount | Returns the number of constant parameters in a function. |
CreateModule | Creates a new module and returns a pointer to it. |
CriticalSection | Marks a section of a module as a critical section and will not allow interruption of its execution by other threads. |
Debugger | (System Library) Starts the VTScada debugger. |
DeleteModule | Deletes a module from the system. |
DeleteOptional | Deletes a statement from an action script. |
DeleteState | Deletes a state from a module. |
DeleteStatement | Deletes a statement from a state. |
DeleteVariable | Deletes a variable from a module. |
DelPageFromApp | Deletes a system page from an application. |
FileRootModule | Parses the document file that contains the given module to find the root module in that file. Returns the module value of the root module. |
FindAction | Returns an action from the list of actions in a state. |
FindVariable | Searches for a variable by text name and returns a variable value. |
FirstState | Sets the first state in a module. |
ForceState | Sets the next state to start when the action script completes. |
FormalParms | Returns the number of formal parameters declared in a module. |
GetDefaultValue | Returns a variable's default value. |
GetID | This returns the ID (opcode) of a given function. |
GetInstance | Returns the object value of a module instance. |
GetModuleRefBox | Get Module Reference Box |
GetModuleText | Returns information about a module's document file. |
GetOneParmText | Returns the text for one parameter of a function. |
GetOverrides | Returns an array of OpCodes and the module value that will run when each OpCode is executed |
GetParmText | Returns the text for all parameters of a function. |
GetParserOffset | Returns the offset before the last compiled statement. |
GetReturnValue | Returns a module's return value. |
GetState | Returns the code value for the specified state. |
GetStatement | Returns the code value for the specified statement. |
GetStatementNum | Returns the statement number for the specified statement. |
GetStateText | Returns the text for the specified state. |
GetToken | Reads the next token from a stream and returns the token type. |
GetTransitText | Get Transition Document Text. This function returns information about the documentation of an action. |
GetVariableText | Returns information about the documentation of a variable. |
GetXformRefBox | Get Transform Reference Box. This function returns the reference box for any transform of a module. |
LastSelected | Returns the most recently selected graphics statement. |
ListVars | Returns a list of variables. |
LoadDLL | Loads a Microsoft Windows™ dynamic link library. |
LoadModule | Loads a module from its .RUN files and returns a pointer to that module. |
LValue | Left-hand Side Value. This function returns an indication of whether its argument can be used on the left-hand side of an assignment. |
MakeDAG | Constructs a Directed Acyclic Graph (DAG - an internal function representation). |
MakeNonPersistent | Takes a variable and makes it not persistent. |
MakeNonShared | Takes a shared variable and makes it not shared. |
MakePersistent | Takes a variable and makes it persistent (static). |
MakeShared | Takes a variable and makes it shared. |
MCSInstance | Module Calling Structure Instance. This function returns the object value of a module called by another module. |
MCSMod | Module Calling Structure Module. This function returns the module value from a line of code that calls that particular module. |
ModuleFileName | Returns the full path (including the drive letter) and file name of the document (.SRC) file of a module. |
NParm | Returns the number of parameters listed in a module instance. |
NumParms | Returns the number of parameters of a statement. |
NumSets | Returns the number of statements that are currently active in setting a particular variable. |
NumVariables | Returns the number of variables in a module. |
OwningModule | Returns the module which contains a certain variable. |
ParserSRO | Adds a scope resolution reference to a variable on the top of the PARSER_STACK given the stack and the object variable. |
PersistentSize | Returns the size in bytes of a variable's persistent value size in the persistent value (.VAL) file. |
RemoveParameter | Removes a parameter from a module's parameter list. |
ReplaceStatement | Replaces a statement with another statement. |
ResetParm | Can reset parameters that become latched. |
ResyncDoc | Synchronizes the time and date for the document and .RUN files. |
RUNFileName | Returns the name of the .RUN file for a module including the full drive and path. |
RUNFileVersion | Returns the minimum version of VTScada that can read the .RUN files produced by the current version. |
SaveModule | Saves a module definition to its *.RUN file. |
SetDefault | Sets the default value for a variable. |
SetModuleRefBox | Sets the reference box for a single instance of a module. |
SetLibrary | Sets the library for an application. |
SetModuleRefBox | Sets the default reference box for a module. |
SetModuleText | Sets the module's .SRC file information. |
SetOneParmText | Sets the text for one parameter of a function. |
SetParameter | Sets a parameter in a statement. |
SetParmText | Sets the text for the parameters of a function. |
SetParserParm | Sets the value for the last parameter on the parser stack and returns its own error code. |
SetRefRect | Sets the first four constant parameters of a layered graphic statement. |
SetStateText | Sets the information about the text of a state in a .SRC file. |
SetTransfer | Sets the destination for an action. |
SetTransitText | Sets the information about the documentation of an action in the .SRC file. |
SetVariableClass | Sets the class number of a variable and returns its previous class number. |
SetVariableText | Sets the information about the documentation of a variable in the .SRC file. |
SetVariableType | Sets the data type for the variable, so that only values of that data type can be stored in the variable. |
StateList | Returns a list of states for a module. |
StatementInstance | Takes a given code value and object and returns a code pointer value for that instance. |
StateName | Returns the text name of the given state. |
SubStatementIndex | Returns the index of a function within the statement where it is called. |
VarAttributes | Returns the attributes bit field of a variable. |
ModifyTags | Can be used to create, modify, or delete running tags. Replacement for StartTag. |
OpChange | Wrapper for TagMigrator\OpChange. Performs an immediate deploy of a single tag change without disturbing any other tag changes already in place on the local branch. |
SimpleOpChange | Immediately deploys a single parameter change on a single tag without disturbing any other tag. Makes use of OpChange. |
StartTag | (Deprecated. See: ModifyTags) Is used to create tags by starting new instances of the tag type specified in the parameter list. When creating an application that requires child tags, it is recommended that this function be used in place of the older ChildLaunch function. |
AcquireLock | Subroutine to acquire an exclusive lock on reading/writing working copy files across all applications. |
AppIsRunning | Reports whether the application has been started and the start-up process is complete. |
AppIsStarted | Returns TRUE if the application has been started. |
AppIsStarting | Returns TRUE if the application is currently in the process of starting. |
ApplyChangeSetFile | Apply a named ChangeSet to an application layer. |
CaptureSettings | Gathers a single property value or an accumulated section and returns the result in a tabular format. |
Combine | Performs a Merge2 operation with automated conflict resolution and change priority. |
CommitEditedFiles | This function compiles and commits edited files if the compile succeeds. |
DirectApply | Applies a set of changes directly to the repository, without disturbing existing (non-conflicting) changes already on either branch. |
EditFile | Informs the configuration management system that a file has been modified in the working copy, typically before making a call to CommitEditedFiles. |
GetAppInstance | Asynchronously, retrieves the Layer object (LayerRoot) for a particular application specified by its GUID. |
GetCodeObj | Retrieves the "Code" object associated with the layer. |
GetINIProperty | Given an array of INIProperty structures, returns the value of a given property from that array. |
GetLoadedAppInstance | Synchronously, retrieves the Layer object (LayerRoot) for a particular application specified by its GUID. |
GetOEMLayer | Retrieves the layer root module of the OEM layer (should one exist) of the layer this is called against. |
GetPlatformInfo | Gathers information about the current application and the workstation it is running on. |
GetWCPath | Returns the full working copy path for an application. |
GetWCRevision | Returns the revision structure for the repository revision currently in use by the working copy. |
HasCompilationErrors | Reports if the working copy presently has unresolved compilation errors |
HasUndeployedChanges | Finds whether the local machine is maintaining changes that have not been deployed, including changes that have been recorded by EditFile but have yet to be committed. |
IsAppEditable | Returns TRUE if the application can currently accept changes without being re-started. |
IsOnLocalBranch | Returns TRUE if the local machine is maintaining changes that have not been deployed within the repository. |
IsRunOnly | Returns TRUE if the application is a run-file-only app, according to the WC contents. |
LayerInUse | Returns true if the application is running, or if there are any applications that depend on this layer, running or not. |
Merge | Applies a set of changes (the output of a Diff operation) to a buffer. |
Merge2 | Attempts to apply two different Diff buffers to a single origin buffer. |
ReadINIProperties | Gathers the sum of all of the properties files in this layer and all of its parents including the local workstation files. |
ReleaseLock | Releases a working copy semaphore that was acquired by AcquireLock. |
ReadPropertiesFile | Reads a single Settings file and returns an INIFile Structure. |
RecordProperty | Helper function used to record settings without needing to explicitly interact with the settings files. |
RepoSubscribe | Allows the caller to specify a callback which will be triggered whenever the application’s repository changes. |
SetINIProperty | Given an INIFiles structure, this function sets the property with the specified name and section to the specified value |
Start | Start an application. |
LayerRoot\Stop | Stop an application. |
WriteINIProperties | The opposite to ReadINIProperties. |
WritePropertiesFile | Write a single Settings file according to the properties in an INIFile structure. |
AddContributor | Adds a contributor to a container. |
DeleteContributor | Removes a contributor from a container. |
GetContributors | Returns a copy of an array of object values of contributors for a given container. |
PContributor | (VTS Library) Draws a splitlist displaying all contributors to a specific tag. |
Base64Decode | Performs a Base64 decode of a buffer. If the two optional parameters are not supplied, this function simply calls Base64Decoder. |
Base64Decoder | Performs a Base64 decode of a buffer. |
Base64Encode | Wrapper for Base64Encoder |
Base64Encoder | Performs a Base64 encode of a buffer |
CheckSignature | Checks a digital signature with a key given a handle returned from Hash(). |
CryptRandom | Returns a buffer of random byte values. |
Decode | Returns the plain value of a cipher that is the result of the Encode function. |
Decrypt | The Decrypt function decrypts data previously encrypted using the Encrypt function. It is the VTScada analog of the CryptoAPI CryptDecrypt call. |
DeriveKey | Generates a cryptographic session key from a seed value. |
Encode | Processes a VTScada string using a configurable selection of compression, encryption, encoding and secure hashing. |
Encrypt | The Encrypt function encrypts data. The algorithm used to encrypt the data is designated by the Key parameter. It is the VTScada analog of the CryptoAPI CryptEncrypt call. |
ExportKey | The ExportKey function exports a cryptographic key or a key pair from a CSP in a secure manner as a Key BLOB. It is the VTScada analog of the Crypto API ExportKey call. |
GenerateHMAC | Calculates the hash-based message authentication code (HMAC) for a given key and input message. |
GenerateKey | The GenerateKey function generates a random cryptographic session key or a public/private key pair. A handle to the key or key pair is returned. This handle can then be used as needed with any CryptoAPI function requiring a key handle. It is the VTScada analog of the CryptoAPI’s CryptGenKey call. |
GenerateSignature | Generates a digital signature of a handle returned from Hash(). |
GetCryptoProvider | The GetCryptoProvider function is used to acquire a handle to a particular key container within a particular cryptographic service provider (CSP). This returned handle can then be used to make calls to the selected CSP. It is the VTScada analog of the CryptoAPI CryptAcquireContext call. |
GetKeyParam | The CryptGetKeyParam function retrieves data that governs the operations of a key. It is the VTScada analog of the CryptoAPI’s CryptGetKeyParam call. |
Hash | Generates a hash - a text string of bytes - of the given string. |
ImportKey | The ImportKey function transfers a cryptographic key from a key BLOB into a CSP (cryptography service provider). It is the VTScada analog of the CryptoAPI’s ImportKey call. |
SetKeyParam | The SetKeyParam function customizes various aspects of a session key's operations. The values set by this function are not persisted to memory and can only be used with in a single session. It is the VTScada analog of the CryptoAPI SetKeyParam call. |
DBAdd | Executes in its own thread to add a record to a VTScada database and returns an indication of parameter errors. |
DBGetStream | Executes in its own thread to convert a database to a stream, and returns an indication of parameter errors. |
DBInsert | Identical to DBAdd, except will not update existing records. |
DBListGet | Executes in its own thread to retrieve certain records from a list in a VTScada database and returns an indication of parameter errors. |
DBListSize | Executes in its own thread to retrieve the size of a certain list in a VTScada database and returns an indication of parameter errors. |
DBRemove | Executes in its own thread to remove a record from a VTScada database and returns an indication of parameter errors. |
DBSystem | Creates a VTScada database and returns its value. The maximum field length is 65,523 characters. If the field length is longer than 65,523 characters, the DBSystem call will return invalid. |
DBTrace | This is a trace engine that records live data to a SQL database. |
DBTransaction | Executes in its own thread to perform a transaction on a VTScada database and returns an indication of parameter errors. |
DBUpdate | Executes in its own thread to update a VTScada database from a given stream and returns an indication of parameter errors. |
DBValue | Returns a certain value retrieved from a VTScada database. |
ODBC | Performs an ODBC command and returns a (dynamically allocated) array if required. |
ODBCBeginTrans | Indicates to a specified ODBC-compliant database that a transaction is to be started. |
ODBCCommit | Indicates to a specified ODBC-compliant database that a transaction is to be committed. |
ODBCConfigureData | Configures an ODBC data source and returns its error code. |
ODBCConnect | Forms a connection to an ODBC-compliant database and returns the ODBC value associated with that database. |
ODBCDisconnect | Stops a connection to the ODBC database. |
ODBCRollback | Indicates to a specified ODBC-compliant database that a transaction is to be rolled back (discarded). |
ODBCSources | Retrieves a list of ODBC data sources and returns it as a (dynamically allocated) array. |
ODBCStatus | Returns the requested information about the last ODBC statement to execute. |
ODBCTables | Retrieves a list of the tables present in an ODBC-compliant database and returns it as a dynamically allocated array. |
RegisterCustomTable | Registers a name for a virtual database table and defines what information will be available from that table. |
SQLQuery | A launched module that executes an SQL query on data in a VTScada application. |
TODBC | Performs an ODBC command. Similar to ODBC except that it runs in its own thread. |
TODBCBeginTrans | Indicates to an ODBC-compliant database that a transaction is to be started. TODBCBeginTrans is similar to ODBCBeginTrans, except that it runs in its own thread. |
TODBCCommit | Indicates to an ODBC-compliant database that a transaction is to be committed. TODBCCommit is similar to ODBCCommit, except that it runs in its own thread. |
TODBCConnect | Forms a connection to an ODBC database. Similar to ODBCConnect except that it runs in its own thread (see "Comments" section for differences) |
TODBCDisconnect | Stops a connection to the ODBC database. Similar to ODBCDisconnect except that it runs in its own thread (see "Comments" section for differences). |
TODBCRollback | Indicates to an ODBC-compliant database that a transaction is to be discarded. TODBCRollback is similar to ODBCRollback, except that it runs in its own thread. |
TServerList | Executes in its own thread and creates a pointer to an array of all servers visible from this workstation. Returns a flag indicating its status upon completion. |
DDE | Returns the value of the data for a specific item from a DDE server program. This function is a DDE client. |
DDEPoke | Sends a value for a specific item to a DDE server program. |
DDEShareAdd | Adds a new DDE share name to the SYSTEM.INI file or the registry and returns its own error code. |
DDEShareDel | Deletes a DDE share name from the SYSTEM.ini file or the registry and returns its own error code. |
SetDDEServer | Sets the DDE topic name for a window. |
ClearVarMetaData | The opposite of SetVarMetaData, this statement removes all metadata associated with a variable. |
Dictionary | Creates a database-like storage structure that provides efficient addition, retrieval and removal of information linked to key values. |
DictionaryCopy | Create a new dictionary with contents identical to an existing dictionary. It is expected that this function will be used rarely, since in most cases it will be more efficient to hand off a reference to a dictionary rather than build a duplicate of it. |
DictionaryRemove | Removes a key / value pair from a dictionary, providing a means to regain memory space and remove data that is no longer needed. |
GetKeyCount | Return a count of the number of keys stored by the given dictionary. |
GetNextKey | Allows a linear search through a dictionary in place. i.e. without copying the contents to an array. |
GetVarMetadata | Every variable object contains an embedded value. This function is used to retrieve those values. |
HasMetaData | Tests whether a given variable is a dictionary. Because the default behavior of most operands and functions on dictionaries is to return just the value of the dictionary’s root, this function provides the only means to determine whether a variable contains a dictionary. |
IsDictionary | A synonym for HasMetadata. Tests whether the parameter is a dictionary. |
ListKeys | Returns an array of all keys used within a dictionary. It is expected that this function will be used primarily in the context of metadata (extended information attached to a variable). ListKeys also enables you to discover what is in a dictionary. |
MakeDictionary | Create and initialize a dictionary with one line of code |
MetaData | If used with a variable which is not currently a dictionary, this command attached meta data to that variable, thereby creating a dictionary object. The primary purpose in this case is to provide a means of associating extended data with a variable. |
RootValue | Retrieves the root value from a dictionary. This function will always attempt to return a value that is not itself a dictionary. If the value stored as the root of the given dictionary is also a dictionary, this function will return the root value from that second dictionary. Should all root values be other dictionaries (which would imply that the dictionary at the end of the chain must actually be an earlier dictionary) then RootValue will traverse the chain until it finds a root value which is an earlier dictionary (i.e. the end of the chain before it loops back) and will return that root value. This is the only situation where the command will return a dictionary as the result. |
SetVarMetadata | Every variable object contains an embedded value. This function is used to set those values. |
AddEditorText | Inserts a text string into a text editor. |
CurrentLine | Deprecated. Returns the text string that is the current line in an editor. |
Editor | Deprecated. Displays an editor on the screen. |
ForceEvent | Deprecated. Forces the editor to perform an action based on the information provided. |
GoToOffset | Deprecated. Forces an editor to move to a location in its text. |
MakeEditor | Returns an editor value which is used by an editor |
MoveEditor | Deprecated. Moves the Editor to the given line and column. |
SetEditMode | Sets the graphics edit mode for a window. |
ZEditField | Draws a layered text edit field in a window and returns a status value. |
SendMail | Sends a string to an email server using the Simple Mail Transport Protocol (SMTP) |
ValidateEmailAddrs | This subroutine validates a string of email addresses, and returns TRUE if the email addresses in the string are syntactically valid, or FALSE if they are not. |
CheckFileExist | (System Library) This subroutine checks for the existence of the specified file. |
CheckPathExist | (System Library) This subroutine checks for the existence of the specified path. |
CopyDir | (System Library) This subroutine recursively copies a directory's files and sub-directories down through the entire directory tree. |
Dir | Performs a search in the given directory and returns an array of matching file names. |
FileChooser | Provides an edit box for specifying a file name, along with a label and a browse button. |
FileDialogBox | Displays a threaded system common file dialog box. |
FileFind | Performs a recursive search down through the directory tree structure and returns an array of matching file names. |
FileSize | Returns the size of a disk file in bytes. |
FileStream | Returns a stream attached to a disk file or printer, and is suitable for use in SWrite. |
FRead | Reads values from a formatted file and returns the number not read. |
FWrite | Writes ASCII or binary data to a file and may also be used to create or delete a file. It returns the number of data items not written. |
Get | Deprecated. Reads an array of historical data from a file (written by Save or SaveHistory) and returns the relative file position of the file entry following the last one read, or an error code. |
GetFileAttribs | Returns information about the specified file. |
GetHistory | Deprecated. Get History from a File written by Save or SaveHistory. This threaded function retrieves an array of data from a .DAT file for a certain time span. If the parameters to GetHistory are valid and an attempt is made to get the data, the return value is 0, otherwise, if no attempt is made to get the data, the return value is 1. |
GetLog | This launched module returns an array of logged data. Marked for removal, but still in use as of VTScada 12.0. Use GetTagHistory instead for all new code. |
GetLogInfo | Deprecated. Interrogates a historical data file, or a set of historical data files, and returns overall time, date, and record count information either for the entire file(set), or for a specified time range. |
LoadMIB | Loads a specified MIB or set of MIBs and returns a dictionary describing the hierarchy of the MIBs. |
MkDir | Creates a directory on a disk and returns its own error code |
ModifyConfiguration | Provides a safe way to write to configuration files. |
ReadConfiguration | This function provides a safe way to read configuration files. |
ReadINI | This subroutine read a variable entry from a Settings file or a buffer containing one and returns its value. |
ReadSectINI | This subroutine read an entire section entry from a Settings file or a buffer containing one and returns a 2-dimensional array containing variable names and their values. |
Rename | Renames an existing file. |
RmDir | Destroys a directory on a disk and returns its own error code. |
Save | Deprecated. This threaded function stores data in a circular historical data file at times indicated by a condition and returns the record number last written to disk. |
SaveFile | Helper function to save files or streams on a server, VIC or Anywhere Client. |
SaveHistory | Deprecated. This threaded function saves an array of data to a .DAT file for a certain time span. |
SetCodeText | Will modify a source code file to replace the text for a given CodeValue with the new text. |
SetFileAttribs | Sets the attributes of the specified file. |
SpeakToFile | Executes on the speech thread to speak the supplied text to a .wav format audio file. |
SplitPath | Breaks up a file path name into its components. |
TempFileStream | Uses the OS tmpfile() function to create a temporary file on disk and to connect a stream to the temporary file. The temporary file is removed when the stream is closed or no longer referenced or if the VTScada process is terminated. |
TGet | Deprecated. This threaded function reads an array of historical data from a file (written by Save or SaveHistory) and returns an indication of parameter errors. |
WriteHistory | (Historian Manager Library) This subroutine writes a variable's value to a Settings file or a buffer containing one and returns its error code. |
WriteSectINI | (System Library) This subroutine writes an entire section to a Settings file or a buffer containing one and returns its error code. |
XMLWrite | Converts the instance of a type, as specified by XMLNodeTreeIn, into XML. |
ReportError | Post error information to VTS Trace and optionally, to the display. |
4BtnDialog | (System Library) Draws a message dialog with up to 4 buttons and 3 lines of text and returns the number of the button that was pressed. |
AlignSelected | Deprecated. Aligns selected graphic objects. |
Bevel | (System Library) Draws a titled beveled box. |
BitmapInfo | Returns information about an image. |
CaptureImage | Creates an image handle from a GUIStretch operation |
CheckBox | (System Library) Draws a check box with (optional) label. |
Click | Returns an indication of whether the mouse pointer is within a specified screen area and a particular button combination is being pressed. |
CommitFocused | This function causes any edit field, while being edited, to output the value currently found in that field. |
Coordinates | Deprecated. Sets the VTScada screen coordinate limits (also called "world coordinates") used by the graphics functions. |
CoordToPixel | Takes a specified coordinate pair within a given window and returns the overall, onscreen pixel location. |
Crop | Modifies an existing image, producing a new one that displays a sub-section of the original. |
DateSelector | Displays a calendar, from which operators can select a date. |
DialogInitPos | (System Library) Attempts to position a dialog so that it is not started beyond the left, right, top, or bottom of the visible screen. |
DragHandle | Drags a selected graphic object's selected handle. |
DrawArcPath | Draws an arc in any window. |
DrawChordPath | Draws a chord in any window. |
DrawEllipticalPath | Draw an ellipse in any window. |
DrawPath | Draws a polygon in any window. |
DrawPiePath | Draws a pie in any window. |
DrawScale | (Meter Parts Library) Will draw a scale (i.e. tick marks) for a linear or radial type meter. These marks are images (normally lines) indicating the major and minor divisions of the entire scale. This function must be called inside a GUITransform to work properly. |
DropList | (System Library) Draws a droplist with (optional) title or bevel or both. |
Edit | (System Library) Draws an edit field with (optional) title or bevel or both. |
EditINI | (VTS Library) Draws an edit field from which a value of an application property in Settings.Startup may be set. |
EditINICheckBox | (VTS Library) Draws a check box with which an application property in Settings.Startup may be set true or false. |
Editor | Displays an editor on the screen. |
FocusID | Returns the focus ID of the object in a window that currently has the input focus. |
Folder | (System Library) Draws a tabbed folder dialog. |
Font | Returns a font value. |
FontDialog | Displays a threaded system common font dialog box. |
Freeze | Freezes all or selected animated graphics in a window. |
GetDisplayRoot | Climbs the call tree looking for the best display context. |
GetPathBound | Returns the bounding box coordinates for a path. |
GetSelected | Returns a selected graphic item in a window. |
GetSelectedInfo | Returns information about selected graphic item(s) in a window. |
GetShapePath | Returns the path value which defines the shape of a polygon. |
GetSystemColor | Returns the colors for the user-configured Windows colors. |
GetTrajectoryPath | Returns the Path value which defines the trajectory of a graphic object. |
GetTransform | Returns the transform value applied to a graphic statement. |
Grid | Places a (lined) grid pattern on the screen. |
GridList | (System Library) Draws a list in the style of a spreadsheet. |
GUIArc | Draws an arc in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIBitmap | Draws an image of any of the following formats in a window and returns an indication when selected by a mouse button or the <ENTER> key. Available formats include: BMP, EMF, WMF, APM, CUT, PCX, JPG, PNG, and TIF |
GUIButton | Draws a push-button in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIChord | Draws a chord in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIEllipse | Draws an ellipse in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIPie | Draws a pie-shaped wedge in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIPipe | Deprecated. Use PathDraw. Draws a 3 dimensional, shaded pipe in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIPolygon | Draws a multi-sided polygon in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIRectangle | Draws a rectangle in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUIText | Draws formatted text in a window and returns an indication when selected by a mouse button or the <ENTER> key. |
GUITransform | Applies a graphical transformation to all graphics in a module and returns an indication when selected by a mouse button or the <ENTER> key. |
HScrollbar | (System Library) Draws a horizontal scrollbar and returns its position. |
HoursEntry | Displays a time editing field. |
IconMarker | Deprecated. Creates the question mark and exclamation mark graphics, used to indicate questionable and manual data in a widget. |
ImageArray | Reads an existing image handle and returns another one containing an image created from that handle by tiling the image a given number of times. |
ImageSweep | Reads an existing image handle and returns another one containing an image created from that handle by tiling the image a given number of times along an arc-shaped path. |
IPAddressList | Displays a list of IP address which can be added to or removed from. |
LinearIndicator | (Meter Parts Library) Will draw a linear type indicator. A linear indicator can be drawn in 3 different ways: Scaled from min to current position, cropped from min to current position or as a line that moves to the current position. This function must be called inside a GUITransform to work properly. |
LinearLegend | (Meter Parts Library) Draws a legend (i.e. the text labels) for a linear type meter. They are drawn in a line, either horizontally or vertically, with consistent spacing. This function must be called inside a GUITransform to work properly. |
Listbox | (System Library) Draws a listbox with scrollbar (if required) and indicates the selected item. |
MakeBitmap | Loads an image file of types BMP, EMF, WMF, APM, CUT, PCX, JPG, PNG, or TIF into memory and returns a handle to the result. Returns Invalid upon failure. |
MapDraw | Draws a "slippy" map, showing a list of site tags as pins on that map. |
ModifyBitmap | Reads an existing image handle and produces a new one with modifications. The original image is not altered. Returns invalid upon failure. |
MoveWindow | Will move a window to the specified coordinates. |
NextFocusID | Moves the focus position to a specific ID number. |
Normalize | Returns a normalized value. |
NumSelected | Returns the number of selected graphics statements in a window. |
Output | Deprecated. Places formatted numbers or text on the screen. |
ParentWindow | Returns the object value of the nearest non-child window. |
PasteObjects | Pastes the code for multiple GUITransforms into a page source file. |
Path | Returns a graphics path value. |
PathDraw | Used within a Idea Studio handler to inform the engine that a path is being drawn, and to set the appearance of that path |
Pending | Returns the number of statements of a certain type pending. |
Pick | Returns an indication of whether the locator (e.g. mouse) has had a specified change in its button status. |
Pipe | Deprecated. Draw a Double Line |
PhraseDroplist | Language-sensitive droplist. |
PhraseEdit | Language-sensitive editfield. This module draws an editfield with (optional) title and bevel. |
Plot | Displays a plot of a subsection of a numeric array in a particular area of the window. |
PlotBuff | Displays a plot of a subsection of a buffer in a particular area of the window after converting the buffer to element values. |
PlotXY | Displays a plot of a curve in the window given the X and Y values in two arrays. |
Point | Returns a two-dimensional point, or location, in a window. |
Popup | (Alarm Manager module) Causes an alarm pop-up dialog to display. |
PrintDialogBox | Displays a threaded system common printer selection dialog box. |
ProgressBar | Displays a horizontal progress bar. |
RadialIndicator | (Meter Parts Library) Will draw a radial type indicator that sweeps from a minimum angle to a maximum angle in the same fashion that a real radial meter would. |
RadialLegend | (Meter Parts Library) Draws a legend (i.e. the text labels) for a radial type meter. They are drawn at a constant radius from the center point of the drawing coordinates, beginning at a defined minimum angle and ending at a defined maximum angle. |
RadioButtons | (System Library) Draws a set of labeled radio buttons with (optional) title and border. |
RootTransform | Returns the object value that contains the root transform applied to the given module. |
Rotate | Returns a Rotate value, which specifies a rotation about a point. |
SaveImage | Takes an image handle and saves it to an image file on disk. |
SectionControl | (System Library) Creates a control that displays a variable number of sections. Visually, a section consists of a header and content. The control manages the layout and geometry for the sections and runs a caller-supplied module to display the section content. |
SelectArea | Selects active graphics statements within a rectangular area in a window. |
SelectCodePointer | Given a window object and a code pointer for an active graphics object within that window, this function adds the graphics object to the window's selection set. |
SelectDAG | (i.e. Select Function) This function selects an active graphics DAG. |
SelectGraphic | Selects an active graphics statement at a location in a window. |
SelectHandle | Returns a pointer to a handle of selected graphics statements at a location in a window. |
SelectHandleNum | Selects the given handle of selected graphics statements in a window. |
SelectPath | Selects a path given its code pointer value. |
SetCursor | Sets the mouse cursor type for the window. |
SetHandle | Sets the position of graphics handles in a window. |
SetXLoc | Sets the X screen location of the locator (mouse). |
SetYLoc | Sets the Y screen location of the locator (mouse). |
ShowPage | When called with a Page Name, will cause that page to display in the caller's display session context |
SimulateMouse | Sets the pointer location and sends a button press with modifiers such as Ctrl, Shift or Alt. (mouse) |
SpinBox | (System Library) Draws a spinbox with (optional) label. |
SplitList | (System Library) Draws a split list (listbox with two columns) with a scrollbar if required and indicates the selected item. |
SplitListSelector | (System Library) Draws a split view comprising two GridLists separated by control buttons. Items listed on the left may be selected to be transferred to the right. Items on the right may be returned to the left so long as they were originally listed on the left. Scrollbars will be drawn if required. |
SplitTagSelector | Draws a split view comprising two GridLists separated by control buttons. Tag names listed on the left may be selected to be transferred to the right. Each GridList will have two columns: the name and the description of each tag in the list. Scrollbars will be drawn if required. |
StopPage | Subroutine to close all instances of a page. |
Tag | Returns a Tag value, which works like (and in place of) a Normalize value. |
TagIconMarker | Draws an "IconMarker" in the center of its transform area, and optionally shows a blank icon when in editing mode. |
TextAttribs | Returns graphic-related information about a text, given a font. |
TextBox | (System Library) Displays a text string, breaking it into multiple lines at space or CRLF. |
ToolBar | (System Library) Draws and maintains a toolbar and its buttons. |
Trajectory | Move a Layered Graphic and return a Trajectory value. |
TreeControl | Implements a tree control similar to that used by the Microsoft Windows Explorer folder panel. |
UnselectGraphics | Will deselect all of the graphics in the specified window. |
UnselectObject | Will deselect a statement in the context supplied. |
UnTransform | Will undo a previous transform so that the module instance and everything it has called will not be transformed. |
UpdateCoordinates | Will update a graphic statement's coordinates to the document file in which it is specified. |
Vertex | Returns a Vertex value, which is a collection of 3 points and a mode. |
VScrollbar | (System Library) Draws a vertical scrollbar and returns its position. |
WebBrowser | Displays a web browser at the given position in the current VTScada window |
WebBrowserNavigate | Call this to cause a WebBrowser to change pages. |
WinButton | Windows native button. |
WinComboCtrl | Windows native "combo" control. A "combo" control is an enhanced form of drop list. Displays a child window containing a Windows combo control. |
WinEditCtrl | Windows native edit control. This function returns a value indicating the status of an edit field. |
WinTooltipCtrl | Windows native "tooltip" control. A "tooltip" is a pop-up text window that provides operational hints to users when the mouse pointer is rested over a tool or object. |
WinYLoc | Returns the Y coordinate of the locator (mouse) in a window. |
XLoc | Returns the X window coordinate of the locator (mouse). |
YLoc | Returns the Y window coordinate of the locator (mouse). |
ZBar | Draws a layered bar in a window. |
ZBox | Draws a layered box in a window. |
ZButton | Draws a layered button in a window and returns true when selected. |
ZEditField | Deprecated. Draws a layered text edit field in a window and returns a status value. |
ZGrid | Draws a layered point grid in a window. |
ZLine | Draws a line between given x and y coordinates in a window. |
ZPipe | Deprecated. Draws a layered three-dimensional pipe in a window. |
ZText | Draws a layered text label in a window. |
A special sub-set of the Graphics tools, these are used only in tag configuration panels. All are members of the dialog library.
PAddressEntry | Used for Tag I/O address entry. |
PAlmPriority | Draws a droplist of the currently available alarm priorities with an optional title and bevel. |
PAreaSelect | Draws a droplist of area options with (optional) title and bevel. |
PCheckBox | Parameter Setting check box. This module draws a check box with (optional) label. |
PColorEdit | Wrapper module for the standard color editing parameters |
PColorSelect | Draws a button that opens a color selection dialog and an area that displays the currently selected color. |
PContributor | Draws a split list displaying all contributors to a specific tag. |
PDroplist | Parameter Setting Droplist. This module draws a droplist with (optional) title and bevel. |
PEditField | Parameter Setting Editfield. This module draws an editfield with (optional) title and bevel. |
PEditName | Tag name setting editfield. This module draws an editfield that is to be connected to the name of a tag. Should be used by all tag ConfigFolder modules for setting the name parameter. |
PFileChooser | Parameter setting file selection. Provides an edit box for specifying a file name, along with a label and a browse button. |
PHSliderBar | Connects a horizontal slider bar to a given parameter number. |
PHueSelect | Connects a hue selection tool to a given parameter number. |
PImageSelect | Connects an image selection tool to a given parameter number. |
PIPAddressList | Uses an IPAddressList to set a parameter with a semicolon-delimited IP address list. |
PIPListenerGroup | Draws a droplist of all available IP Listener Groups. |
PMultiCheckBox | Display the standard set of check boxes. |
POverride | Tool used to override non-standard ConfigFolder controls for child tags. |
PPageSelect | Draws a titled, beveled droplist of pages in the system. |
PPhraseDroplist | Handles the complexity of parameter expressions by switching between display of a PhraseDroplist and regular Droplist control as is done in PPhraseEdit. |
PPhraseEdit | Draws a language-sensitive editing field. |
PRadioButtons | Draws a set of labeled radio buttons with optional title and border. |
PSecBit | Draws a titled, [beveled] droplist of options for setting the security bit. |
PSelectObject |
Draws a beveled, titled box showing the currently selected tag, a button to modify the connection in the hierarchy, and a new tag creation button. |
PServerListName | Called graphic module that creates an editable droplist of Server List Names, available to the tag. |
PSpinbox | Parameter Setting Spinbox. This module draws a spinbox with (optional) label. |
PTimeZone | Parameter Setting Droplist. Tool used to display a list of timezones, as defined by the operating system. |
PTypeToggle | Parameter Setting Type Toggled Field. This module draws a beveled droplist or editfield with title that sets a tag or numeric value. |
SiteDispParms |
Parameter setting tool for Site List display options. While not part of the dialog library, and not starting with the letter "p", this is still classified as one of the PTools. |
EnableHelp | Enables you to enable or disable help file activation when the F1 key is pressed. |
Help | Calls Windows™ help. |
SetHelp | Sets the help file name and (optionally) the context identifier for the window containing the specified object. |
KeyCount | Returns the number of keys pressed since the state became active, either edited or non-edited. |
KeyFake | Places a string of characters in a window's keyboard buffer. |
Keys | Returns the most recently pressed keys from either the edited or non-edited keystrokes. |
MatchKeys | Returns true if the specified keyboard keys have been pressed in the sequence given. |
WinMatchKeys | Returns true if the specified keyboard keys have been pressed in the sequence given in another window. |
WinShiftKeys | Deprecated. Returns a value which contains the current status of the Shift, Control and Alt control keys. |
CurrentWindow | Returns the application window over which the mouse cursor currently rests. |
LocCapture | Capture Locator Input. This statement captures all subsequent input from the locator device and routes it to a specific window. |
LocSwitch | Returns the current status of the locator (mouse) buttons over the window which contains the LocSwitch statement. |
Target | Returns an indication of whether the locator (e.g. mouse) is within a specified screen area. |
WinLocSwitch | Returns the current status of the locator (mouse) buttons in a certain window and its ancestors. |
EditData | (Historian Manager Library) Subroutine to write the new history value and to write the data note for manual data editing. |
Get | Reads an array of historical data from a file (written by Save or SaveHistory) and returns the relative file position of the file entry following the last one read, or an error code. |
GetHistory | Get History from a File written by Save or SaveHistory. This threaded function retrieves an array of data from a .DAT file for a certain time span. If the parameters to GetHistory are valid and an attempt is made to get the data, the return value is 0, otherwise, if no attempt is made to get the data, the return value is 1. |
GetLogInfo | Interrogates a historical data file, or a set of historical data files, and returns overall time, date, and record count information either for the entire file(set), or for a specified time range. |
GetTagHistory | (Historian Manager Library) Launched module that retrieves historical data for a tag. Replaces GetLog. |
HistorianConnect | Opens a logging connection and controls the lifetime of all resources associated with that connection. |
LogNTEvent | Logs events to the system event log. |
SaveHistory | This threaded function saves an array of data to a .DAT file for a certain time span. |
TGet | This threaded function reads an array of historical data from a file (written by Save or SaveHistory) and returns an indication of parameter errors. |
Boolean | (System Library) Takes a valid Boolean test and returns the numeric equivalent. |
Case | Selects one of a set of parameters for execution and returns its return value. |
Cond | Returns one of two values depending upon the result of a conditional expression. |
DoLoop | Executes a do-while loop in a script. |
Execute | Executes a group of statements as a single entity in structures that would otherwise allow only one statement to be executed. |
False | Evaluates to 0 or tests whether an optional parameter evaluates to 0. |
IF | Trigger to perform an action. It changes the active state in a module instance or executes a script or does both. |
IfElse | Executes one of its two parameters based upon a condition parameter. |
IfOne | Check for an If One Condition. This function checks for a race condition in an action script and returns the value of the location. |
IfThen | Conditionally Execute Statements. This statement executes a statement if the condition parameter is true. |
Invalid | Return Invalid Value. This function always returns an invalid value. |
PickValid | Attempts to return a valid value given a list of parameters. |
True | Evaluates to 1 or tests whether an optional parameter evaluates to 1. |
WhileLoop | Repeatedly executes a parameter while a condition is true. |
ABS | Returns the absolute value of a numeric expression. |
CommaFormat | Returns the text version of a number, formatted to use embedded commas. |
Deriv | Returns the derivative (rate of change) of a value. |
Edge | Performs a test for a rising or falling edge. |
Exp | Returns the natural antilogarithm of a numeric expression. |
FFT | Performs a fast Fourier transform between time and frequency domains. |
FitOffset | Linear regression offset. This function returns the offset or Y intercept of the least square curve fit of data in a pair of arrays. |
FitR2 | Returns the coefficient of determination (i.e. r2) for a linear curve fit. This number gives a measure of how correct the curve fit is. |
FitSlope | Linear regression slope. This function returns the slope of the least square curve fit of data in a pair of arrays. |
FormatInteger | Returns a text string which is a decimal value converted to one of binary, octal or hexadecimal formats. |
Intgr | Time Integral. This function returns the time integral of a value. |
Ln | Returns the natural logarithm (base e) of a value. |
Log | Returns the common logarithm (base 10) of a number. |
Max | Returns the maximum of a group of parameters. |
Min | Returns the minimum of a group of parameters. |
Pow | Returns a number raised to a power. |
Rand | Returns a random number between 0 and 1. |
Scale | Returns a value that has been converted from one scale to another. |
Sqrt | Returns the square root of a number. |
SumBuff | Returns the summation of bytes in a buffer. |
Ceil | Returns the smallest integer greater than or equal to a number (the ceiling). |
DeadBand | Returns the previous value of the first parameter until it changes by an amount specified by the second parameter. |
Int | Integer Portion of Number. This function returns the portion of a number before the decimal point. Also used for rounding. |
FormatNumber | Returns a compactly formatted version of a number, containing at least the specified number of significant digits. |
Limit | Set Value Minimum and Maximum. This function returns a value that is limited both on the high and low ranges. |
Step | Transforms a continuous value into discrete steps. |
ACos | Calculates the trigonometric arc cosine in radians. |
ASin | Returns the trigonometric arc sine in radians. |
ATan | Returns the trigonometric arc tangent in radians. |
Cos | Returns the trigonometric cosine of an angle in radians. |
Sin | Returns the trigonometric sine of an angle in radians. |
Tan | Returns the trigonometric tangent of an angle in radians. |
AddRead | Add a read request. This module is called by a tag to add a request to read a specific range of memory and set the resulting read data into the variable pointed to by the third parameter. The pointer may be a simple variable for one element read, or an array if more than one element is requested. |
CopyIn | Copies data from an absolute RAM address and returns a buffer. |
CopyOut | Copies data from a buffer to an absolute RAM address. |
DelRead | Is called by a tag to delete an existing read request, as created by an AddRead. |
In | Read I/O Byte. This function returns the byte read from an I/O port. |
InWord | Read I/O Word. This function reads a 16 bit unsigned word from an I/O port. |
MakeFixedBuff | Creates a buffer value which has its data stored at a specific memory address. Not supported under 64-bit VTScada. |
MemIn | Returns a byte, word, or longword of RAM memory. |
Memory | Returns the amount of memory that VTScada has acquired from the OS heap for internal use. |
MemOut | Writes a byte, word, or longword of RAM memory. |
MemTrace | Writes memory allocation information to a file. |
Out | Writes an 8 bit byte to an I/O port. |
OutWord | Writes a 16 bit word to an I/O port. |
CallerID | Takes a specified modem stream and returns the caller ID from the telephone system. |
ModemCount | Returns the number of data modems configured and operational in the system. |
ModemDev | Obtains the identifier for a modem sub-device. (In order to use the audio capabilities of a voice modem, the device identifier for the wave output device is required.) |
ModemDial | Dials and attempts to connect to a remote modem and returns the modem stream or an error code. |
ModemDigits | Controls the receipt of DTMF digits entered from the keypad of a telephone engaged on a voice call via a voice modem. |
ModemList | Returns a list of the modems in the system. This function should be used to determine the correct parameter for the ModemStream or ModemDial functions. |
ModemMedia | Enables you to determine the media mode of a serial stream open on a modem, and change it if necessary (for example, if you require the ability to be able to handle both incoming voice mode and data mode calls). |
ModemStream | Open a serial stream on a modem and returns its status (prior to the connection being made), a modem stream (after the connection has been established), or an error code. |
ModemTransfer | Transfers a modem call to another application and returns an indication of success. |
PPPDial | Creates a PPP connection to a remote peer. The connection can be via a dial-up or direct device connection. |
PPPHandles | Returns an array of all Point-to-Point Protocol handles on the local machine. |
PPPDial | Describes the status of a PPP connection. |
CleanModule | Removes the flag that marks when a module that has been changed programmatically and would therefore have its changes saved to disk were this flag not cleared. |
CodeText | Returns the text (or other information) for a given Code Value. |
CoverageSnapshot | Captures the areas in a VTScada source file which have not executed along with summary statistic for each module in the file to extract code coverage information. |
CrossReference | Returns a linked list of structures representing all references to a specified variable or module. |
GetParameter | Returns the requested parameters as a constant, variable or code pointer. |
ImportAPI | Imports objects of class API from a given module, for use in the calling module. |
Pack | Packs a set of module parameters or an array of values into a stream, and returns the number of items that were not packed. |
ParentModule | Returns the parent module of a module. |
ParentObject | Returns the parent object of a module. |
ParmToBuff | Returns a buffer of formatted numeric parameter values. |
PType | Returns the actual type of parameter at an index. |
SetOverride | Allows the overriding of OpCodes with a specified script module within a static module tree. |
ChildInstances | Returns the object values of module instances that are children of a particular module instance (i.e. all objects whose parent is a specified object). |
GetTagList | Returns an array of tags, starting at a given point in the tag tree and including all child tags below that point, subject to the filtering parameters. |
GetTagMode | Returns text or a structure to identify what kind of tag a given instance is. |
GetTagTypes | Returns an array of either the common names or the module names of all tag types. |
HasReturnStatement | Examines a specified object to see if it is currently running a return statement in steady-state. |
Instance | Limit Module Instances. This function limits the number of fixed module instances allowed to run simultaneously and returns the old limit |
IsChild | Identify Child Module. This function returns an indication of whether one module is a child module of another. |
Launch | Runs a module instance and returns a pointer to it. |
LocalScope | Equivalent to Scope(Obj, Name, TRUE). LocalScope is a useful shortcut where the second parameter is not a constant string. |
LocalVariable | LocalVariable(Name) is a shortcut for Scope(Self, Name, TRUE). |
NumInstances | Returns the number of module instances currently running. |
Parameter | Returns the value of (or may assign a value to) a parameter of a module, specified by the index. |
PointList | Returns an array of tag names within the current scope, given the name of a tag type or group. |
Return | Sets the return value for the module in which it is executed. |
RootWindow | Returns the object value of the root (original) module displayed in the same window. |
Scope | Performs a scope resolution and returns a reference to the requested member within a module or other object. |
ScopeLocal | Deprecated. As above except that ScopeLocal will not look outside the given context. |
Self | Returns the object value of the current module. |
SetInstanceName | Set the name of an instance of a module. |
SetReturnValue | Sets the return value of a specified object if the object is not currently running a Return() statement in steady state. |
Slay | Stops a launched module, and possibly any parent modules. |
SystemSelf | Returns the object value of the system module for the given application. |
Thread | Launches a module in its own separate thread. |
ThreadHistory | Returns in an array the history of execution for a specified thread. |
ThreadIdle | Returns TRUE when the ToDo list for a given thread is empty. |
ThreadList | Returns a two dimensional array containing the name and statement last executed by each VTScada thread. |
ThreadName | Returns the name of a thread. |
ThreadPriority | Allows advanced users to set a specified thread to one of six priorities, ranging from idle to time critical. |
WCSubscribe | Working Copy Subscribe. After this function has been called, any configuration change will result in the specified callback subroutine being called. |
Window | Opens a new window, starts a module inside, and eventually returns the module's value. |
See also: RPC Manager Functions.
CheckIPMask | Determines whether an IP Address is in the address ranges defined by MaskSet. |
GetAdaptersInfo | |
GetGUID | Creates a globally unique identifier or converts an existing GUID to another format. |
GetHostByName | Calls the WinSock gethostbyname function and returns the host name, address(es) and alias names for the named computer. |
GetPowerState | Returns a structure that describes the state of the power supply to the workstation. Relevant when the workstation is running on battery power. |
IPMaskToText | Extracts an IP mask from MaskSet and converts it to text, returning the new text value. |
LocalGroup | Returns an indication of whether the current Windows™ user is a member of the specified local group. LocalGroup interrogates only local groups, not domain groups. |
MakeIPMask | Make an IP mask set by returning text holding the encoded binary IP address and mask. Works for IPv4 and IPv6. |
OPCServer | Adds a new top-level branch to the VTScada OPC Server’s namespace hierarchy. |
Platform | Returns a twelve element structure that indicates the platform under which VTScada is currently running. |
Redirect | Redirects a local device to network resource. |
Register (RPC Manager) | (RPC Manager Library) This subroutine registers a service for RPC and returns a pointer to the variable containing the current RPC status of the service. |
RunPack | (RPC Manager Library) Is unpacks and executes a set of RPCs from a stream constructed with PackRPC. |
Send | (RPC Manager Library) This subroutine sends a message by invoking a remote procedure call (RPC). |
ServerList | Returns a pointer to an array of all available servers visible from this workstation. |
ServerSocket | Returns a server WinSock socket stream given a handle returned by a SocketServerStart function or an integer error code. |
SetAllBlocks | (RPCManager Library) This subroutine executes on the client. It accepts all of the blocks and data for a service. |
SetOPCData | Sets an item value in the VTScada OPC Server. |
WKSList | Generates a list of sub-paths from the query returned by the WKSPath function. |
WKSPath | Given set of path components, generates a query path for use in the WKSStatus command. |
WKSStatus | Sends a query to the Windows™ Performance Monitor interface (see image in WKSPath) and returns the result as a query handle. |
WKStaInfo | Returns the characteristic information about this workstation. |
AddConnection | (ODBC Manager Library) Called to get the object value of an ODBC connection. If the connection does not exist, then a new ODBC DSN connection will be created and explicitly added to the ODBC Manager's internal list of DSN's |
ErrMessage | (ODBC Manager Library) Returns a text message for the error code handed to it as a parameter |
ResultFormat | (ODBC Manager Library) Subroutine to convert 2-d array as returned from query in the form, Arr[Field][Rec], to a normalized format of Arr[Rec][Field]. |
TableSynch | (ODBC Manager Library) Synchronizes the fields matching a specified criteria within matching tables in two databases. Should be run as a called module, waiting for completion. Do not call as a subroutine. |
TODBCConnect | Forms a connection to an ODBC database. Similar to ODBCConnect except that it runs in its own thread. |
TODBCDisconnect | Stops a connection to the ODBC database. Similar to ODBCDisconnect except that it runs in its own thread. |
Transaction | (ODBC Manager Library) Launches a transaction in the specified database connection. The transaction takes care of its own shut-down process. |
TransactionCached | (ODBC Manager Library) Launches a transaction in the specified database connection. The transaction will be cached locally if it fails and then sent to the database after the next successful transaction. This module is designed to provide logging of values that must not be lost. |
DefaultPrinter | Returns the Windows® default printer. |
Allows text to be printed. | |
PrintLine | Allows text to be printed and is followed by a carriage return-line feed to the printer. |
PrtScrn | Prints the image in a window on the default Windows® printer and returns an error code. |
ProtobufDecode | Decodes Protobuf serialized data. |
ProtobufEncode | Creates a buffer for a given Protobuf file containing VTScada value data. |
ProtobufInstantiate | Instantiates a message using default values. |
ProtobufParse | Load a Protobuf specification from a file. |
GetOutputTypes | Returns a list of available report output type plugins. |
GetReportTypes | This subroutine returns a list of available report type plugins. |
BinIP2Text | (RPC Manager Library) Returns a text representation of a specified binary IP in a printable format. |
ConnectToMachine | (RPC Manager Library) This subroutine increments the usage count on the specified workstation and forces RPC Manager to attempt to establish a connection with the specified workstation if it is not already connected. Subroutine call only. |
DisconnectFromMachine | (RPC Manager Library) This subroutine disconnects from a workstation by decrementing the usage count on the specified workstation and forcing the RPC Manager to attempt to establish a connection with the specified workstation if it is not already connected. Subroutine call only. |
ForceServers | (RPC Manager Library) Sets the servership of an application service to a specific state. |
GetAllWorkstationNames | (RPC Manager Library) Launched module that creates an alphabetically sorted list of all known workstation names. The list is not service specific. |
GetClientDiverts | (RPC Manager Library) Returns a one-dimensional array of flags, indicating the divert status of each client. |
GetClientGUIDs | (RPC Manager Library) Returns a one-dimensional array of the application GUIDs of the clients of the specified RPC service instance. |
GetClientIPs | (RPC Manager Library) Returns a one-dimensional array of the IPs of the clients of the specified service instance. |
GetClientList | (RPC Manager Library) Returns a one-dimensional array of the names of the clients of the specified service instance. Steady state or subroutine call. |
GetClientMode | (RPC Manager Library) Returns a one-dimensional array of the modes of the clients of the specified service instance. |
GetClientNodes | (RPC Manager Library) Returns a one-dimensional array of the object values of the MachineNodes of the clients of the specified service instance. Steady state or subroutine call. |
GetInhibitedServiceList | (RPC Manager Library) Returns a one-dimensional array of the names of all services inhibited from RPCManager servership control. |
GetInSyncServers | (RPC Manager Library) Returns a one-dimensional array of the names or IPs of the potential, synchronized servers for the given service. |
GetIP | (RPC Manager Library) Returns an IP address for a workstation, given its name. |
GetLocalIP | (RPC Manager Library) Returns an IP address for the local workstation that is known to the specified remote workstation. |
GetLocalNumber | (RPC Manager Library) Returns the index of the local workstation down the prioritized server list for the named service. Steady state or subroutine call. |
GetMachineNode | (RPC Manager Library) Returns the object value of the MachineNode for the specified name or IP. Steady state or subroutine call. |
GetMakeAltPtr | (RPC Manager Library) Returns a pointer to a variable containing the Alternate status for the local service instance in the calling application for the specified service. Steady state or subroutine call. |
GetRemoteVersion | (RPC Manager Library) Returns the version number of VTScada running on a specified workstation. Steady state or subroutine call. |
GetServer | (RPC Manager Library) Returns the name of the currently active server for a specified service. |
GetServerChanges | (RPC Manager Library) Launched by RPC Manager on a service server to obtain the service's synchronization data (i.e. called by RPC Manager during startup synchronization on a server to get the package of RPCs that create a synchronizable state on the client which is in step with the server). |
GetServerMode | (RPC Manager Library) Returns the mode in which the current server for a specified service is running. |
GetServerNumber | (RPC Manager Library) Returns the index down the prioritized server list of the current server for the specified service. Steady state or subroutine call. |
GetServerSIDPtr | (RPC Manager Library) Returns a pointer to a variable that holds the session ID for the current server for the specified service. |
GetServersListed | (RPC Manager Library) This subroutine returns a one-dimensional array of the names or IPs of the servers that has been derived from the "-Servers" section of the service configuration file. |
GetServiceScope | (RPC Manager Library) Returns the service instance for a service. |
GetSessionID | (RPC Manager Library) Returns the current session ID for a specified application on a workstation. |
GetSocketStatus | (RPC Manager Library) Returns the connection status of either: 1) The machine node if the subnet is not valid, or 2) The socket that is on the specified subnet. |
GetStatus | (RPC Manager Library) Returns a variable that holds the current service instance status for the specified service. |
IsClient | (RPC Manager Library) Is Client of a Service. This subroutine returns an indication of whether a particular workstation is a client connected to a service. Returns 1 for the specified service if the specified machine is currently a client to the machine on which the IsClient() call is made. |
IsMatch | (RPC Manager Library) Determines whether two names or IPs indicate the same workstation. This subroutine returns a 1 if the two names or IPs (any combination) refer to the same workstation. |
IsPotentialServer | (RPC Manager Library) Is Potential Server for a Service. This subroutine returns an indication of whether the local workstation is a potential server for a service. Returns 1 if the local workstation can be a server for the specified service. IsPotentialServer should not be called in steady state. |
IsPrimaryServer | (RPC Manager Library) Returns 1 if the local machine is connected to the primary server for the specified service. |
IsServiceReady | (RPC Manager Library) Is Primary Server Active for a Service. Only available in VTS 6. This module returns an indication of whether the specified server is in synchronization with the server instance. Returns 1 if the local instance is in synchronization with the server instance. |
PackParms | (RPC Manager Library) This method packs supplied parameters into a stream. Subroutine call only. |
PackRPC | (RPC Manager Library) Packs an RPC call and a set of parameters into a stream. Subroutine call only. |
ReadLock | (RPC Manager Library) Attempts to acquire a Read lock for the specified service. Subroutine call only. |
RecommendAlternate | (RPC Manager Library) Instructs RPC Manager that the local service instance does not consider itself a good server candidate. |
RecommendPrimary | (RPC Manager Library) Instructs RPC Manager that the local service instance considers itself a good server candidate. |
Register (RPC Manager) | Registers a service for RPC and returns a pointer to the variable containing the current RPC status of the service. |
Send | (RPC Manager Library) This subroutine sends a message by invoking a remote procedure call. |
SetDivert | (RPC Manager Library) Informs RPC Manager that the synchronization state of a service has been sampled during synchronization, and service RPCs for the specified client should be buffered until synchronization completes. Subroutine call only. |
SetRemoteValue | (RPC Manager Library) This subroutine sets the specified variable within an application instance on a workstation to the specified value. Subroutine call only. |
SetSyncComplete | (RPC Manager Library) Informs RPC Manager that service synchronization is complete as far as the local service instance is concerned. Subroutine call only. |
TextIP2Bin | (RPC Manager Library) Returns the Binary representation of the specified IP. |
UnpackData | (RPC Manager Library) This method unpacks a stream into an array or set of module instance parameters. Subroutine call only. |
UnpackParms | (RPC Manager Library) This method unpacks a stream into the supplied parameters. Subroutine call only. |
WriteLock | (RPC Manager Library) This subroutine attempts to require a Write lock for the specified service. Subroutine call only. |
Account Manipulation Methods
AddAccount | Creates a new account. |
ModifyAccount | Modifies an existing account. |
DeleteAccount | Removes an account. |
Query Module
SecurityCheck | Examines the rules that apply to the current user or the named user to determine if the specified privilege has been granted. |
BuildFullName | If a namespace and namespace delimiter are being used, returns the full, namespace-qualified name of the specified account. |
GetFullName | Returns the full, namespace-qualified name of the caller's account. |
GetGroupName | Returns the namespace of the caller's account. |
GetUserName | Returns the user name of the caller's account. |
GetAccountID | Returns the account ID of the named account. |
GetAccountInfo | Returns one or more AccountData structures. |
IsLoggedOn | Returns TRUE if the calling user is logged on, else FALSE. |
IsSecured | Returns TRUE if the application has any user accounts defined, else FALSE. |
IsSuspended | Returns TRUE if the user's account is suspended, else FALSE. |
UIErrorToText | Returns a text string corresponding to the error code provided. |
VTScada Authentication Module
AlternateIdCheck | Searches the accounts for an account whose AltID matches the parameter value. |
AlternateLogon | Either creates, or attempts to log in using an alternate ID value. |
AlternateLogoff | Synonym for LogOff(). |
Authenticate | Authenticates the NameSpace, UserName and Password. |
QuietLogon | Authenticates the authorization token (AuthToken) and, if successful logs the calling user session on as the user specified in the AuthToken. |
LogOff | Logs the calling user session off. |
UserCredChange | The return value will increment each time there is a change in the user session's logged-in user or their password. |
Windows Authentication Module
AcceptSecurityContext | Accepts a Kerberos security context from a client and returns the user principal name (UPN) from the context, along with any output to be returned to the client for mutual authentication. |
DefaultNamingContext | Returns the string value of the LDAP default naming context for the host machine domain. |
GetLogonCredentialsFromSmartcard | Monitors the card reader for a smartcard and reads the certificate information from it |
WindowsLogon | Authentication request to Windows Authentication services. |
User Interface Module
UserLogonDialog | Launches the Logon dialog. |
Other
VICSmartcardMonitor | Enables and disables Smartcard monitoring on a VIC and outputs authentication information received from the VIC when a Smartcard is used. |
VICSmartcardResponse | Returns the result of the Kerberos Security negotiation after processing a sign in attempt on the VIC. |
COMPort | Opens a serial port and handles all interrupts and asynchronous events for that serial port, including transmission, reception, and control. It returns its own error code. Please note that the SerialStream function is generally preferred in many situations, however, ComPort continues to be supported. |
SerBreak | Sends a break character to a serial port. |
SerCheck | Check Serial Port. This function returns the immediate or cumulative serial port status. |
SerialStream | Returns a serial stream that can be used in any of the serial port functions or with any of the stream functions. Please note that the ComPort function (which functions somewhat differently than the SerialPort function) may also be utilized. |
SerIn | Get Serial Port Byte. This function returns the next byte in the receive buffer. |
SerLen | Serial Port Buffer Length. This function returns the number of bytes currently in the receive or transmit buffers. |
SerOut | Send Serial Port Byte. This statement sends a byte to the transmit buffer. |
SerRcv | Serial Port Receive. This function returns a buffer containing a string read from the receive buffer. |
SerRTS | Sets or clears the RTS line on a serial communication port. |
SerSend | Serial Port Send. This function writes a string to the transmit buffer and returns the number of bytes written. |
SerStrEsc | Serial Port Receive With Escape. This function reads the receive buffer until an escape code is encountered and returns the final offset in the buffer. |
SerString | Serial Port String Receive. This function reads the receive buffer until a string is encountered and returns the final offset in the buffer. |
CommandLine | Returns any command line arguments as a text string. |
DriveInfo | Returns information about a disk drive. |
GetConfiguration | Returns the configuration parameters from the license key for this copy of VTScada. |
IsRunning | Check if a Program is running. This function returns an indication of whether a certain program is currently running on the same computer. |
LoadDLL | Loads a Microsoft Windows™ dynamic link library. |
MACID | Enumerates and returns the MAC IDs registered on a particular machine. |
ProcInfo | Returns basic information about the VTScada process. |
SerialNum | Returns the serial number of the copy of VTScada running. |
Spawn | Runs another Windows™ program. |
Stop | Causes the immediate termination of VTScada, closing all windows. |
Version | Returns the version number of the copy of VTScada currently running. |
VersionRequired | Returns the version number of VTScada that is required to execute any .RUN files loaded since the last execution of this statement. |
VStatus | Returns the video board and screen characteristics for VTScada. |
AudioFileLength | (System Library) Returns the length of a RIFF format Wave file in seconds. |
Beep | Causes a tone to sound on the computer's internal speaker. |
Configure | Is used to define how a speech stream will sound and where it will be heard. |
GetDevices | Runs in the VoiceTalk thread and returns a list of devices available on a SAPI text-to-speech stream. |
GetVoices | Runs in the VoiceTalk thread and returns a list of voices available on a SAPI text-to-speech stream. |
MuteSound | (Alarm Manager module) This subroutine is used to turn off alarms sounds for all alarms, both current and future. |
Play | Plays a multimedia sound file as installed in the operating system. It differs from Sound in that it is a steady-state statement and is supported by the VTScada Internet Client (VIC). |
Reset | Immediately stops a speech stream and cancels any buffered speech. |
ShowLexicon | Displays a SAPI text-to-speech engine lexicon dialog to permit modification of pronunciation. This function will return immediately, and the lexicon window will be managed in its own thread, preventing the calling thread from being blocked. |
Sound | Plays a multimedia sound file as installed in the operating system. |
Speak | Executes on the speech thread to speak the supplied text through a specified SAPI text-to-speech stream. |
VoiceTalk | Opens and returns a handle to a SAPI text-to-speech stream. |
ActiveState | ActiveState returns the code value of the currently active state in the given module instance. |
AddOptional | Adds a new statement to an action script and returns its own error code. |
AddPageToApp (Obsolete) | Creates a new application page. |
AddState | Adds a new state to an existing module and returns its state value. |
AddStatement | Adds a new statement to an existing state and returns its own error code. |
ClearState | Deletes all of the statements in a state. |
DeleteOptional | Deletes a statement from an action script. |
DeleteState | Deletes a state from a module. |
DeleteStatement | Deletes a statement from a state. |
FindAction | Returns an action from the list of actions in a state. |
FirstState | Sets the first state in a module. |
ForceState | Sets the next state to start when the action script completes. |
GetState | Returns the code value for the specified state. |
GetStatement | Returns the code value for the specified statement. |
GetStatementNum | Returns the statement number for the specified statement. |
GetStateText | Returns the text for the specified state. |
ReplaceStatement | Replaces a statement with another statement. |
SetStateText | Sets the information about the text of a state in a .SRC file. |
SetTransfer | Sets the destination for an action. |
StateList | Returns a list of states for a module. |
StatementInstance | Takes a given code value and object and returns a code pointer value for that instance. |
StateName | Returns the text name of the given state. |
SubStatementIndex | Returns the index of a function within the statement where it is called. |
BlockWrite | Writes a block of data to a stream. |
BuffStream | Returns an in-memory read/write (expanding) buffer stream. |
ClientSocket | Opens a client WinSock-compliant socket stream and returns a stream value, or a numeric error code. |
CloseStream | Closes and flushes any type of open stream and returns its own error code. |
DBGetStream | Executes in its own thread to convert a database to a stream, and returns an indication of parameter errors. |
Flush | Pushes the data in all software caches associated with a FileStream directly to the physical media. |
GetStreamLength | Returns the present length of a stream in bytes. |
GetStreamType | Returns a type indication for a stream. |
GetToken | Reads the next token from a stream and returns the token type. |
HTTPSend | Sends HTTP requests to an HTTP server |
ListCertificates | Enumerates X.509 certificates in a certificate store resident on the local computer. |
PeekStream | Returns a string of bytes from a stream without removing them from the stream. |
PipeStream | Returns a stream based on an operating system named pipe. |
Read | (VTSDriver Library) Used to create a request for a single read of a given driver address. (This is in contrast to the polled read request of the AddRead function). |
ReadBlock | (VTSDriver Library) Is launched to read a block of data from the PLC. It maintains a linked list of pointers to tag values with their absolute offset into the PLC file being read by this instance. |
Seek | Changes and returns the current position within a stream. The return value is the current stream position after the seek is done. |
ShiftStream | Inserts or deletes characters from a stream and returns its own error code. |
SocketAttribs | Returns information about a TCP/IP socket's attributes. |
SocketPingSetup | Starts the transmission of automatic keep-alive "ping" messages through a socket stream. |
SocketServerEnd | Ends a TCP/IP socket server. |
SocketServerStart | Starts a TCP/IP or UDP socket server and returns a handle to it. |
SocketServerManager\Register | Register a station with a group |
SocketServerManager\UnRegister | Unregister a station from a group. The station must be unregistered whenever GroupName, or StationKey changes. |
SocketWait | Wait for Socket Connect. This function returns true when a client connects to a socket offered by a socket server. |
SRead | Reads values from a formatted stream and returns the number of values not read. |
StreamEnd | Returns whether a stream is at the end. |
SWrite | Performs a formatted write of ASCII or binary data to a pre-existing stream and returns the number of data items not written. |
Unpack | Unpacks a set of values from a stream into a single dimensional array or a set of variables referenced by object parameters, and returns the number of items unpacked. |
Write | (VTSDriver Library) Used by a tag to create a write request to a driver address. |
ArrayToBuff | Returns a buffer containing the numeric data from an array. |
BuffOrder | Reverses the order of groups of bytes in a buffer, and returns a new (rearranged) buffer. |
BuffRead | Reads values from a formatted buffer and returns its own error code. |
BuffToArray | Reads an array from a formatted buffer containing numerical data and returns the number of elements read. |
BuffToHex | Convert a buffer of numeric data to a hexadecimal value. |
BuffToParm | Convert buffer of numeric data to parameters. This function reads module parameters from a formatted buffer containing numerical data and returns the number of data items read. |
BuffToPointer | Converts a buffer of numeric data to array of pointers. This function reads from a formatted buffer containing numeric data, writes to locations specified by an array of pointers, and returns the number of elements read. |
BuffWrite | Writes formatted values to a buffer and returns the number of values not written. |
CharCount | Returns the number of bytes in a section of a buffer that matches a search character. |
ClipboardGet | Returns the current contents of the system clipboard as a string. This function enables an application to perform text "paste" operations. |
ClipboardPut | Set the current contents of the system clipboard to a string. This function enables an application to perform text "copy" or "cut" operations. |
Concat | Returns the text value that is the concatenation of all the text parameters. |
CRC | Returns the cyclic redundancy check (CRC) value for a buffer. |
CRCTable | Returns a buffer containing a CRC table. |
Deflate | Compresses/decompresses a buffer of data using the DEFLATE algorithm, and returns the compressed/decompressed data. |
Diff | Compares two buffers and generates a third buffer containing formatted instructions describing how the first buffer can be modified so that it will match the second. This will perform a delimited difference unless the ChunkSize parameter is set to 1 or greater. |
FileChooser | Provides an edit box for specifying a file name, along with a label and a browse button. |
Format | Returns a text string corresponding to numbers in a specified format. |
FRead | Reads values from a formatted file and returns the number not read. |
FWrite | Writes ASCII or binary data to a file and may also be used to create or delete a file. It returns the number of data items not written. |
GetByte | Returns a single byte from a buffer. |
GetDatePhrase | Returns a formatted date for the current user's locale |
GetTimePhrase | Returns a formatted time for the current user's locale |
GetParmPhrase | Returns parameterized text in the currently selected language for a given phrase identifier key. |
GetParmPhraseForLang | Returns parameterized text in the specified language for a given phrase identifier key |
GetPhrase | Returns text in the currently selected language for a given phrase identifier key |
GetPhraseForLang | Returns text in the specified language for a given phrase identifier key |
GetRawPhrase | Returns a phrase in the provided language, if it exists. |
HexToBuff | Converts a hex string to a binary buffer. |
JoinStrings | Joins an array of string elements together into one string, with a given separator added between each element from the array. |
JSON_Encode | Deprecated. Use JSONEncode instead. |
JSONEncode | Converts any given VTScada value into a JSON string using UTF-8 encoding. |
JSONParse | Parse JSON text, converting it to VTScada arrays, objects/structures, strings or other data types as appropriate. |
Locate | Locates a text string, returning the offset of the first matching string in a buffer. |
MakeBuff | Creates a buffer and returns its address. |
MakeValidFName | Create a file name that is guaranteed to contain only legal characters. |
PatternMatch | Compares a string against a reference pattern and returns true if the string matches the pattern. Along with literal characters, PatternMatch currently supports the * and ? wildcard characters within the reference pattern. |
PointerToBuff | Returns a buffer containing the numeric data from the variables pointed at by each element of the array. |
PrepStringForTemplate | Prepares text for use in an alarm template by escaping % symbols. |
Replace | Performs a search and replace operation on a buffer and returns the resulting buffer. |
Reverse | Returns its parameter with the byte order reversed. |
SetByte | Writes a single byte to a buffer. |
SplitString | Splits a string into separate array elements using a given delimiter to mark the breaks between elements in the string. |
StrCmp | Performs a case sensitive comparison of two text expressions and returns an indication of whether the first string is greater than, less than or equal to the second. |
StrICmp | Case Insensitive Text Comparison |
StrJustify | Reformats a string to have maximum line length. |
StrLen | Returns the length of a text string. |
SubStr | Returns a string that is a portion of another string. |
TextEncode | Takes text in the local code page and converts it into UTF-8 encoded text where a suitable conversion exists. |
TextSearch | Returns the array index of the first occurrence of the given text key in an alphabetically ordered array. |
TextSize | Returns the size in characters of the definition text of a desired item. |
TrimSpaces | Returns text with leading and trailing spaces removed. |
ToLower | Returns a text string with all the characters converted to lower case. |
ToUpper | Returns a text string with all the characters converted to upper case.. |
WrapText | Breaks a text string based on given font and width and returns the text segments in an array. |
AbsTime | Absolute time. This function returns true when a fixed time has been reached. |
ConvertTimeStamp | Converts a timestamp from one time zone to another. |
CurrentTime | Returns the number of seconds, in local or UTC time, since midnight of January 1, 1970 (where "midnight" is 00:00). |
Date | Returns a text string giving the date that corresponds to the number of days since January 1, 1970. |
DateNum | Returns the number of days since January 1, 1970 for a given date. |
DateSelector | Displays a calendar, from which operators can select a date. |
Day | Returns the day of the month for a given date number. |
Month | Returns the month for a given date number. |
Now | Returns the current time in seconds since midnight. |
RTimeOut | Cumulative Timer. This function returns true when the total time that an expression is true reaches the specified value. |
Seconds | Returns the number of seconds since midnight of the current day. |
SetClock | Sets the VTScada system clock and calendar. |
Time | Returns a formatted string for a time of day. |
TimeArrived | Indicates whether a given time has occurred. |
TimeOut | Returns true when the uninterrupted time that an expression is true reaches the specified value. |
TimeUtils | Library that exposes a dictionary of time periods and subroutine to calculate relative time periods. |
TimeZone | Returns information on the current time zone setting of the machine. |
TimeZoneList | Returns an array of names of time zones that are available on the system. |
Today | Returns the current number of days since January 1, 1970. |
Year | Returns the year for a given date number. |
Accumulate | Adds a tag and a value to be counted for that tag, to a named accumulator. |
AddVariable | Adds a new variable to an existing module and returns its variable value. |
Cast | Takes a value and returns a different type of value, if possible. |
Change | Returns a true when the value of the first parameter changes by at least the value of the second parameter. |
Changes the space allocated in the persistent value (.VAL) file for a variable. | |
CheckTagGroup | Returns TRUE or FALSE according to whether a tag is in the specified group. |
DeleteVariable | Deletes a variable from a module. |
Dictionary | Creates a database-like storage structure that provides efficient addition, retrieval and removal of information linked to key values. |
DictionaryCopy | Create a new dictionary with contents identical to an existing dictionary. It is expected that this function will be used rarely, since in most cases it will be more efficient to hand off a reference to a dictionary rather than build a duplicate of it. |
FindVariable | Searches for a variable by text name and returns a variable value. |
GetDefaultValue | Returns a variable's default value. |
GetReferencedValues | Collect all dynamically referenced values in the call tree rooted at the parameter and return them in an array. |
GetSessionContainers | Returns an array of the names of tags that are "container" tags that exist at any level under the given context (parent) tag |
GetSessionContainerTags | Returns a dictionary of tag items below a given context (parent) tag |
GetStructInfo | Returns names and counts of all instantiated structures. |
GetUserID | Returns the name of the user for the current session. |
GetModuleContext | Returns the context of a given module-in-context. |
GetRetainedValue | Given the name of a variable whose value was retained, this function will load the retained value from storage. The function also provides the option of deleting the files holding that value. |
GetValue | Returns the current count of the values within an accumulator dictionary. |
GetVariableText | Returns information about the documentation of a variable. |
GetVariableType | Returns the type, BASEVALUE, stored within a variable. |
GetVarMetadata | Every variable object contains an embedded value. This function is used to retrieve those values. |
HasMetaData | Tests whether a given variable is a dictionary. Because the default behavior of most operands and functions on dictionaries is to return just the value of the dictionary’s root, this function provides the only means to determine whether a variable contains a dictionary. |
IsEqual | Will return TRUE if the parameter values are equivalent, or if both are invalid. |
IsDictionary | A synonym for HasMetadata. Tests whether the parameter is a dictionary. |
Latch | Latch On or Off. This function allows a transient change of a variable to be captured. Its return value is determined by the rules listed in the comments section. |
ListKeys | Returns an array of all keys used within a dictionary. It is expected that this function will be used primarily in the context of metadata (extended information attached to a variable). ListKeys also enables you to discover what is in a dictionary. |
ListVars | Returns a list of variables. |
LValue | Left-hand Side Value. This function returns an indication of whether its argument can be used on the left-hand side of an assignment. |
MakeNonPersistent | Takes a variable and makes it not persistent. |
MakeNonShared | Takes a shared variable and makes it not shared. |
MakePersistent | Takes a variable and makes it persistent (static). |
MakeShared | Takes a variable and makes it shared. |
MetaData | If used with a variable which is not currently a dictionary, this command attached meta data to that variable, thereby creating a dictionary object. The primary purpose in this case is to provide a means of associating extended data with a variable. |
NumSets | Returns the number of statements that are currently active in setting a particular variable. |
NumVariables | Returns the number of variables in a module. |
PersistentSize | Returns the size in bytes of a variable's persistent value size in the persistent value (.VAL) file. |
PID | Perform PID Controller Function. This function returns a control value to maintain a parameter at a given setpoint. |
PTypeToggle | (VTS Library) Parameter Setting Type Toggled Field. This module draws a beveled droplist or editfield with title that sets a tag or numeric value. |
RootValue | Retrieves the root value from a dictionary. This function will always attempt to return a value that is not itself a dictionary. If the value stored as the root of the given dictionary is also a dictionary, this function will return the root value from that second dictionary. Should all root values be other dictionaries (which would imply that the dictionary at the end of the chain must actually be an earlier dictionary) then RootValue will traverse the chain until it finds a root value which is an earlier dictionary (i.e. the end of the chain before it loops back) and will return that root value. This is the only situation where the command will return a dictionary as the result. |
SetDefault | Sets the default value for a variable. |
SetVariableClass | Sets the class number of a variable and returns its previous class number. |
SetVariableText | Sets the information about the documentation of a variable in the .SRC file. |
SetVariableType | Sets the data type for the variable, so that only values of that data type can be stored in the variable. |
StaticSize | Returns the size of a given variable, provided that the variable is static. |
StrictlyEqual | Will return TRUE if the parameter values are of the same type and also are equivalent, or if both are invalid. |
StrictlyNotEqual | Complement to StrictlyEqual. |
Struct | Returns a dictionary, using the provided parameters as keys. |
Toggle | Returns its previous status value except when its parameter changes from a false to a true, in which case it changes its value. |
Valid | Returns true if the parameter is valid. |
ValueType | Returns the type of value passed to it. |
Variable | Accesses a variable by its text name. The return value is optional. |
VariableClass | Returns the class of a variable. |
Watch | Watches its parameters and returns true when any of their types or values change. |
WatchArray | Watches an array and returns true if any of its elements' types or values change. |
WatchForTagChanges | Watches for tag changes, either external or local. (Deprecated) |
WatchTags | Watches for tag changes, either external or local. (Use instead of WatchForTagChanges) |
IsVICSession | Returns TRUE to indicate that a call is being made from a VTScada Internet Client session. |
NotifyVIC | Sends a message to the VTScada Internet Client (VIC). The message sent depends on the parameter given to the function. |
SetVicParms | Sets parameters for the VTScada Internet Client. |
VICInfo | Provides information about the currently connected VTScada Internet Clients. |
VICMessage | Transmits a message to one or all currently connected VTScada Internet Client sessions. The message is displayed in a dialog box on the VIC computer. |
ActiveWindow | ActiveWindow returns the object value of the root module instance in the current active window. |
Click | Returns an indication of whether the mouse pointer is within a specified screen area and a particular button combination is being pressed. |
Cls | Clears the screen and sets its background color. |
Coordinates | Sets the VTScada screen coordinate limits (also called "world coordinates") used by the graphics functions. |
CoordToPixel | Takes a specified coordinate pair within a given window and returns the overall, onscreen pixel location. |
Crop | Modifies an existing image, producing a new one that displays a sub-section of the original. |
DelPageFromApp | Deletes a system page from an application. |
FocusID | Returns the focus ID of the object in a window that currently has the input focus. |
Freeze | Freezes all or selected animated graphics in a window. |
GetXformRefBox | Get Transform Reference Box. This function returns the reference box for any transform of a module. |
MoveWindow | Will move a window to the specified coordinates. |
ParentWindow | Returns the object value of the nearest non-child window. |
SetCursor | Sets the mouse cursor type for the window. |
SetEditMode | Sets the graphics edit mode for a window. |
SizeWindow | Changes the visible size of a window on the screen. |
WindowClose | Returns true if an attempt to close the window is made. |
WindowOptions | Alters the options on a window after it has been opened. |
WindowSnapshot | Creates an image file containing a screen capture of the specified window. |
GetXMLNodeArray | Searches the result returned from XMLParse and returns an array of XMLNode values of a given type. |
RemWSDL | Disconnects a Realm from a WSDL file and the associated set of VTScada modules, cleaning up any resourced used by that web service. |
SetWSDL | Connects a Realm with a WSDL file and a set of VTScada modules to enable a web service interface. |
XMLAddSchema | Adds a schema to an XML Processor. |
XMLCloneNode | Clones an existing XMLNode, optionally adding additional members. |
XMLCreateNode | Creates a new XMLNode. |
XMLDeleteMember | Deletes a member from an XMLNode in-place. |
XMLGetNode | Returns an XMLNode from a tree. |
XMLParse | Parses the supplied XML using the specified XML Processor. |
XMLProcessor | Creates a new XML Processor. |
XMLWrite | Converts the instance of a type, as specified by XMLNodeTreeIn, into XML. |
