SocketServerManager\UnRegister
| Description: |
Unregister a station from a group. The station must be unregistered whenever GroupName, or StationKey changes. |
| Returns: |
Invalid when complete |
| Usage: |
Script |
| Function Groups: |
Stream and Socket |
| Format: |
\SocketServerManager\UnRegister(Context, StationKey, GroupName) |
| Parameters: |
| Context |
| Required. The context should be the root tag. This must have Discriminator() and Context() subroutines. |
| StationKey |
| Returned by Discriminator() in the root tag. An opaque string used to identify a particular station. |
| GroupName |
| The name of an IPListener tag (or group). This will be the source of the new data streams. |
| Comments: |
Users should wait until \SocketServerManager\Started is true before attempting to use the Register or Unregister functions. |
Example:
ActiveDevAddr{PLC address to use in reads & writes };
ListenerGroup{SocketServerManager group to join };
IPAddressAllow{ Semicolon delimited string of IP addresses (or ranges
which can connect to this station};
If Valid(Name) && \SocketServerManager\Started && Watch(1, ActiveDevAddr, ListenerGroup, IPAddressAllow);
CriticalSection(
IfThen(Valid(ActiveDevAddr) != Valid(RegDevAddr) || ActiveDevAddr != RegDevAddr ||
Valid(ListenerGroup) != Valid(RegGroup) || ListenerGroup != RegGroup,
\SocketServerManager\Unregister(Root, RegDevAddr, RegGroup);
RegDevAddr = ActiveDevAddr;
RegGroup = ListenerGroup;
{ Register with SocketServerManager }
\SocketServerManager\Register(Root, RegDevAddr, RegGroup, IPAddressAllow);
Trihedral and VTScada are registered trade marks of Trihedral Engineering Limited
© Trihedral Engineering Limited 1983- 2022 All rights reserved.
