Date Codes (predefined)
Use any of the following numeric date codes to format a data as shown. If you require a custom format, you can build one using the text codes shown in Date Formatting Strings.
Dates using these codes will always be displayed in English, regardless of system configuration.
All examples showing Monday, August 13, 2012.
Use only the number in the first column - the second two describe the result of the code in the first column. They are not codes that you can use in the function.
| Date Code | Example | Description |
| 0 | no date | |
| 1 | 120813 | yyMMdd |
| 2 | 08/13/12 | MM/dd/yy |
| 3 | 08-13-12 | MM-dd-yy |
| 4 | Aug 13, 2012 | MMM d, yyyy |
| 5 | August 13, 2012 | MMMM d, yyyy |
| 6 | 13 Aug 12 | dd MMM yy |
| 7 | 13 Aug 2012 | dd MMM yyyy |
| 8 | 13/08/12 | dd/MM/yy |
| 9 | 13-08-12 | dd-MM-yy |
| 10 | 13Aug12 | ddMMMyy |
| 11 | 13Aug2012 | ddMMMyyyy |
| 12 | Aug 13/12 | MMM d/yy |
| 13 | 20120813 | yyyyMMdd |
| 14 | 08/13 | MM/dd |
| 15 | 08-13 | MM-dd |
| 16 | 08/12 | MM/yy |
| 17 | 08-12 | MM-yy |
| 18 | 08/2012 | MM/yyyy |
| 19 | 08-2012 | MM-yyyy |
| 20 | Aug 13 | MMM d |
| 21 | August 13 | MMMM d |
| 22 | Aug 2012 | MMM yyyy |
| 23 | August 2012 | MMMM yyyy |
| 24 | 13/08 | dd/MM |
| 25 | 13-08 | dd-MM |
| 26 | Aug | MMM |
| 27 | August | MMMM |
| 28 | 12-08-13 | yy-MM-dd |
| 29 | 12/08/13 | yy/MM/dd |
| 30 | 2012-08-13 | yyyy-MM-dd |
| 31 | 2012/08/13 | yyyy/MM/dd |
| 32 | 12-W35-01 (1) | yy-WeekOfYear-DayOfWeek (2) |
| 33 | 12/W35/01 | yy/WeekOfYear/DayOfWeek |
| 34 | 2012-W35-01 | yyyy-WeekOfYear-DayOfWeek |
| 35 | 2012/W35/01 | yyyy/WeekOfYear/DayOfWeek |
| 36 | 12226 | yyDayOfYear |
| 37 | 2012226 | yyyyDayOfYear |
| 38 | 12-226 | yy-DayOfYear |
| 39 | 12/226 | yy/DayOfYear |
| 40 | 2012-226 | yyyy-DayOfYear |
| 41 | 2012/226 | yyyy/DayOfYear |
| 42 | Mon, 13 Aug 2012 | ddd, d MMM yyyy |
(1) Week Of Year is preceded by the character W.
(2) "DayOfWeek" and "WeekOfYear" are descriptions rather than format codes that you could use.
Time Codes (Predefined) - Use for displaying time.
Date - The function that uses the codes listed above.
