Configuration Examples
It is very common to underestimate just how much control VTScada gives you through configuration properties. A few examples might help to expand the horizon:
Alarm Properties
AckAllRequiresConfirmation - force operators to confirm that they meant to use Ack All.
MinMuteDuration - Set the minimum time duration for alarm muting.
AlarmSpeechEnable - speak alarms at the server.
NoteRequiredForShelve - force operators to record why they are shelving an alarm.
AlarmPriorityIndicatorColor - set the color of an Alarm Priority widget displaying a shelved or disabled alarm.
Security
MaxFailedLoginAttempts - How many attempts before the account is locked for X minutes.
MaxRateFailedLoginAttempts - How frequently attempts can be made before switching from the maximum attempt value used for operators to the maximum value used for automated cracking programs.
Tags
RememberNewTagParameters - Whether new instances default to the values from the last instance created.
DefaultAnalogDeadbandFractionOfFullScale - The default deadband when logging analog values.
ParmChangedColor - The green background when a tag parameter is changed.
ParmInfoDateFormat - How to display dates in the tag modification tooltip
Application Properties
AutoActivate - Activate and start are not the same thing.
AutoStart - Run this application every time.
DoNotStart - Maybe your OEM layer isn’t meant to run.
HideFromVAM - Maybe it shouldn’t even be seen
NoSoftDriverFailure - Controls whether drivers should switch to backup servers on failed communications.
DriverNameSharedRPC - Controls whether the same service should be used for all instances of the specified driver.
Pages
DefaultPageColor - default page color
ThemedPageBGColor - The background color to use for VTScada system pages.
Page - Default page upon startup
Logging
OperatorLogTemplate - controls what information is included when VTScada logs operator events.
HistorianConnectionRetryDelay - the number of seconds to wait before retrying a connection.
TraceUserConfigActions - Log operational events
