Final Action [FinalCheckBox]
There is sometimes a need to give the user options for actions to perform when the Wizard completes. The WizardEngine provides a method named, "FinalCheckBox" for this purpose. It takes the following three parameters:
- Value: The initial value for the check box, and the returned value.
- Message: The message/label attached to the check box.
- Enable: If true, then the check box is displayed.
This method should only be called from the "Finish" state. It will otherwise be disabled.
Finish [
{ Final Step }
Engine\Finalcheck box(RunNow, "Run the report when the wizard finishes", Valid(RunNow));
If Move;
ForceState(NextState);
IfThen(Move == Forward,
