GetSessionContainerTags
| Context |
| Optional. The name of the tag under which to look for containers. Defaults to VTSDB. |
| DoNotRecurseIntoContainer |
| Optional Boolean. Set TRUE to not recurse into container with details page (default is false). |
| NoContainersInTagsList |
| Optional Boolean. Set TRUE to prevent containers from appearing in the Tags list. Defaults to FALSE. |
| IncludeTagsInSubContainers |
| Optional Boolean. Dpecifies whether to filter out descendents of containers. Normally defaults to false. Defaults to true if Context is an array or if Context tag has contributors |
| NavigationPath |
| Optional array. Unique ID values of the tags that make up the path taken to get to our Context tag. |
| PtrAutoDrilled |
| Optional pointer to an array of the Unique ID values of tags that were skipped (drilled through) to arrive at the Context tag. These will be skipped by the "Go Up" button in the site list user interface. |
| Comments: |
The returned dictionary will have the following structure: Note that container tags use this function to obtain the list to display in a Sites page. If the container tag also includes a module named CustomSiteListGetSubTags or CustomSiteMapGetSubTags, (which must be a subroutine and must return an array of tag names) then GetSessionContainerTags will automatically call that module rather than GetTagList. NavigationPath and PtrAutoDrilled are used only with Context tags that have an optional hook: CustomSiteListGetSubTags or CustomSiteMapGetSubTags. |
