Rotary Control Widget (Knob)![Level 2 topics describe basic development tools typically covered in our Operations and Configuration course.](../Resources/Images/Level2.png)
Used by: I/O and Calculations, Analog Input, Analog Output, Analog Status, Analog Control
The Rotary Control enables operators to select a value to write to hardware by turning a knob. This is done by clicking on, then dragging the control clockwise or counter-clockwise. The value that will be set is shown in a tooltip while dragging.
Properties dialog for the Rotary Control:
Rotary Image
The image that simulates the knob motion by rotating in response to the operator action. Usually a dot or bar that indicates the current position.
If creating your own image, it must be transparent other than the position indicator, which must be directly above the center of the image:
Image Select
Image Adjust
Image Clear
Stationary Image
The background image, providing context for the rotary image.
Minimum Angle / Maximum Angle
Limit the angle through which the control can rotate. In both cases, the angle is measured clockwise from vertical in units of degrees.
Steps
Sets the precision of the control, relative to the scaling value. The default value enables the operator to select 100 possible values within the scale range. This may not be appropriate for all controls.
Confirmation Dialog
When selected, the operator must acknowledge each action before the tag will write to equipment.
Scaling
Choose whether to use the tag's minimum and maximum scaling values or to set alternative scaling values that will be applied to the output value.
Analog Controls\
