Reset Polling History Widget
The Reset Polling History widget is used only by the Enron Modbus Driver. It is drawn as a button, which operators may click to change the next index to be polled back to the first index, which may be a one or zero depending on driver settings. This can be used to re-read all data in the device.
The properties dialog for the Reset History Polling widget:
Tag
History Address
Provide the numeric value of the history address being monitored. History addresses typically start at 701.
Label
Provide a label for the button. This should describe what will happen when an operator clicks this widget.
Confirmation Dialog
When selected, operators must click through a confirmation prompt before the reset will proceed.
Gauges\
