Lift Station Page
This page will use the information from a Station tag to create complete monitoring and control displays for your pumping stations. The lift station page is normally opened by clicking a Site Draw widget that is linked to a station tag. The contents of this page will vary according to the type of station tag linked to it. This page may also be referred to as the Station Details Page.
If you choose to add a menu item for a Lift Station page, you must configure three parameters:
  • The station tag that will be linked to the component widgets.
  • Whether the application's color theme will be applied to the page.
  • The color to use for labels. This may be an RGB value in the form, <RRGGBB>, or it can be a numeric value as specified in the VTScada color palette.
The Station page is an assembly of various monitoring and control drawing methods for the associated station tag. Each component is described in the following sub-topics. The specifics will vary according to whether the station is a MultiSmart, MPE SC series or MPE Duplexer, but most components of the pages will be found for all types of station tag.
