Tag Names in Code
There are several instances where you may need to refer to a tag type by its name in code. For example if using the ODBC interface to query tag parameter data (Select * from Parms_AnalogStatus).
Custom types that you create will use the name that you assigned in the original Context tag.
| Tag | Name in code |
| Allen Bradley DF1 Compatible PLC/RTU | ABDriver |
| Alarm Database | AlarmDatabase |
| Alarm | AlarmPoint |
| Alarm Priority | AlarmPriority |
| Alarm Status | AlarmStatus |
| Analog Control | AnalogControl |
| Analog Input | AnalogInput |
| Analog Output | AnalogOutput |
| Analog Statistics | AnalogStatistics |
| Analog Status | AnalogStatus |
| BACnet Driver | BACnetDriver |
| CIP/ENIP Device | CIPENIPDriver |
| Grundfos Dedicated Controls | CU36XController |
| Grundfos Dedicated Controls Custom Data Log | CU36XControllerCustomDataLog |
| Grundfos Dedicated Controls Event Log | CU36XControllerEventLog |
| Grundfos Dedicated Controls\\Pump | CU36XControllerPump |
| Calculation | Calculation |
| Campbell Scientific Array Driver | CampbellRTU |
| Comm Link Sequencer | CommLinkSequencer |
| Context | ContextTag |
| Counter | CounterTag |
| Simulator Connection | CustomerConnection |
| DDE Client | DDEDriver |
| DNP3 Compatible RTU | DNP3Driver |
| Data Flow System RTU | DataFlow |
| CalAmp Diagnostic Driver | DataradioDriver |
| Deadband Control | DeadbandControl |
| Digital Control | DigitalControl |
| Digital Input | DigitalInput |
| Digital Output | DigitalOutput |
| Digital Statistics | DigitalStatistics |
| Digital Status | DigitalStatus |
| Driver Multiplexer | DriverMUX |
| Enron MODBUS Driver | EnronDriver |
| Omron FINS Driver | FINSDriver |
| Font Style | FontValue |
| Function | Function |
| GE Series 90 Driver | GESeries90Driver |
| Grundfos Control MPC | GrundfosBooster |
| Grundfos Control MPC\\Pump | GrundfosBoosterPump |
| Historian | HistorianTag |
| History Statistics | HistoryStats |
| IEC 60870-5 Driver | IEC60870Driver |
| I/O and Calculations | IO |
| IP Network Listener | IPNetworkListener |
| JSON/XML Driver | JSONXMLDriver |
| Koyo DirectNET | KoyoDriver |
| Logger | LogPoint |
| MDS Diagnostic Driver | MDSDriver |
| MPE Duplexer Station | MPEDuplexer |
| MPE Duplexer Station\\Pump | MPEDuplexerPump |
| MPE SC Station | MPESC |
| MPE SC Station\\Pump | MPESCPump |
| MQTT Client Driver | MQTTClientDriver |
| Menu Item | MenuItemTag |
| Modem | Modem |
| Modbus Compatible Device | ModiconDriver |
| Motorola IP Gateway | MotorolaGateway |
| Motorola ACE RTU | MotorolaRTUDriver |
| MultiSmart Station | MultiSmart |
| MultiSmart Station\\Well\\Profile | MultiSmartProfile |
| MultiSmart Station\\Pump | MultiSmartPump |
| Multi-Write | MultiWrite |
| NMEA 0183 Driver | NMEADriver |
| Network Status | NetworkStatus |
| Notebook | Notebook |
| OPC Client | OPCClientDriver |
| OPC Server Setup | OPCServerSetup |
| OPC UA Client Driver | OPCUAClientDriver |
| Omron Host Link PLC | OmronDriver |
| PLC Alarm | PLCAlarm |
| Campbell Scientific PakBus Driver | PakBusDriver |
| Polling Driver | PollDriver |
| Data Flow Pulse Input | PulseInput |
| Pump Status | Pump |
| Fisher ROC Driver | ROCDriver |
| Rate of Change | RateOfChangeTag |
| Realm Display Setup | RealmDisplaySetup |
| Report | Report |
| Roster | Roster |
| SMS Appliance | SMSAppliance |
| SNMP Managed Device | SNMPDriver |
| SQL Data Query Driver | SQLDataQueryDriver |
| SQL Logger | SQLLogger |
| SQL Logger Group | SQLLoggerGroup |
| Script | Script |
| Selector Switch | SelectorSwitch |
| Serial Port | SerialPort |
| Siemens S7 PLC | SiemensS7Driver |
| String I/O | StringIO |
| Style Settings | StyleSettings |
| Subordinate Application | SubordinateApplication |
| TCP/IP Port | TCPIPPort |
| TI505 Device | TI505Driver |
| Tesco Data Express Plus Driver | TescoDriver |
| Totalizer | TotalizerTag |
| Transaction Logger | TransactionTag |
| Trigger | TriggerTag |
| UDP/IP Port | UDPIPPort |
| Veeder Root Driver | VeederRootDriver |
| WorkStation Driver | WorkStationStatusDriver |
