Omron Error Codes
Error code
(Decimal)
Error code
(Hex)
Meaning
0 0x0 No Error
1 0x1 Not executable in RUN mode
10 0xa Overrun
11 0xb FCS Error (checksum)
12 0xc Format error (parameter length error)
13 0xd Entry number data error
14 0xe Instruction not found
15 0xf Unknown Error Code
16 0x10 Frame length error
17 0x11 Not executable
18 0x12 I/O table generation impossible
19 0x13 Incomplete response to WRITE
2 0x2 Not executable in MONITOR mode
20 0x14 Bad serial port parameters
21 0x15 Serial port already used
23 0x17 No response from PLC (timed out)
24 0x18 Wrong PLC station address responded
25 0x19 TYPE parameter out-of-range
26 0x1a Garbled/Incomplete message
27 0x1b Aborted due to parity error in transmit data
28 0x1c Aborted due to framing error in transmit data
29 0x1d Aborted due to overrun in transmit data
3 0x3 Not executable with PROM mounted
31 0x1f Aborted due to format error in transmit data
32 0x20 Aborted due to entry number data error in transmit data
33 0x21 Aborted due to frame length error in transmit data
34 0x22 Not executable because the program area is not 16K
4 0x4 Address over (data overflow)
49 0x31 Connection Attempt Failed
5 0x5 Not executable in PROGRAM mode
7 0x7 Not executable in LOCAL mode
8 0x8 Parity Error
9 0x9 Framing Error
