OPC Client Error Codes
| Error code (Decimal) |
Error code (Hex) |
Meaning |
| 00 | 0x0 | No Error |
| 01 | 0x1 | Failed to load OPC Automation DLL |
| 02 | 0x2 | Connection request to OPC Server failed |
| 03 | 0x3 | OPCGroups Object not retrieved |
| 04 | 0x4 | Failed to add I/O Group to OPC Server |
| 05 | 0x5 | OPC Server Status is Unavailable |
| 06 | 0x6 | OPC Server is not in Running State |
| 07 | 0x7 | OPC Thread heartbeat fail |
| 08 | 0x8 | Unknown Error |
| 20 | 0x14 | The Value of the Handle is Invalid |
| 23 | 0x17 | The Server Cannot Convert the Data |
| 24 | 0x18 | Requested Operation is not Allowed on Public Groups |
| 25 | 0x19 | The Items access Rights do not Allow the Operation |
| 26 | 0x1a | The Address does not Exist |
| 27 | 0x1b | Syntax Error in Address |
| 28 | 0x1c | The Filter String was not Valid |
| 29 | 0x1d | The Items Access Path is Unknown |
| 30 | 0x1e | The Value was Out of Range |
| 31 | 0x1f | Duplicate Name not Allowed |
| 32 | 0x20 | Server does not Support Requested Data Rate |
| 33 | 0x21 | Attempted Write to Clamped Output |
| 34 | 0x22 | Operation Failed because the Object is In Use |
| 35 | 0x23 | Server Invalid Configuration File Format |
| 36 | 0x24 | Requested Object was not Found |
