Native VTScada Protocols
Definitions:
DH
Dual homed.
Native Serial
Driver supports native serial communication as defined in protocol standard document(s) on PC serial ports using VTScada "Serial Port" tags
Modem
Driver supports native serial communication as defined in protocol standard document(s) over modems defined in the operating system
Native TCP/IP
Driver supports native TCP/IP communication to devices as defined in the protocol standard document(s)
TCP/IP Tunnel
Driver supports tunnelling of serial protocol via Ethernet-connected TCP/IP to serial converters using VTScada "TCP/IP Port" tags
Native UDP/IP
Driver supports native UDP/IP communication to devices as defined in the protocol standard.
UDP/IP Tunneled
Driver supports tunneling of serial protocol via Ethernet-connected UDP/IP to serial converters using VTScada "UDP/IP Port" tags.
Other Connection
Driver supports device or protocol specific interface or methodology not covered by above definitions (e.g. ODBC).
Virtual PLC
Driver supports VTScada acting as a memory-mapped PLC or RTU that other devices can read from or write to.
| Driver Connection | |||||||||||
| Driver Tag Type | Protocol | Example Devices | Native Serial | Modem | Native TCP/IP | TCP/IP Tunnel | Native UDP/IP | UDP/IP Tunneled | Other | Virtual PLC | Additional Information |
| Allen Bradley DF1 Compatible PLC/RTU | Allen Bradley DF1 | PLC2, PLC3, PLC5, SLC500 | X | X | X | X | DH/DH+ | X | DH/DH+ requires the use of additional interface hardware. Supports Virtual PLC in PLC-2 compatible mode only | ||
| Allen Bradley DF1 Compatible PLC/RTU | Allen Bradley PCCC | PLC5, SLC500 | X | ||||||||
| CIP/ENIP Device | Allen Bradley CIP | CompactLogix®, ControlLogix® | X | ||||||||
| Campbell Scientific Array Driver | Campbell Scientific Array Protocol | CR10X and CR510 Data Loggers using array OS | X | X | X | X | |||||
| Campbell Scientific Pakbus Driver | Campbell Scientific Pakbus | CR200, CR800, CR850, CR1000, CR3000, CR5000 Data Loggers | X | X | X | X | X | Security features for native TCP/IP not implemented | |||
| DDE Client | DDE (Dynamic Data Exchange) | MS Excel | DDE | Can act as DDE Client or Server | |||||||
| Data Flow Systems RTU | DFS Protocol | Data Flow Systems® RTUs | X | X | X | Also works with DFS NIM | |||||
| Koyo DirectNET | Direct Net | PLC Direct® DL Family of PLCs | X | X | X | X | |||||
| DNP3 Compatible RTU | DNP 3.0 | DNP 3.0 Compliant Devices | X | X | X | X | X | X | |||
| Enron Modbus RTU | Enron Modbus® | Enron Modbus Compliant Devices | X | X | X | X | X | ||||
| Fisher ROC Driver | Fisher® ROC | ROC800, 800L, FloBoss™ 103, 107 | X | X | X | X | X | ||||
| GE Series 90 Driver | General Electric® SNP, SNPX | GE Series 1 PLC, Series 5 PLC, Series 6 PLC, Series 90 PLC, | X | No direct support for use on Ethernet to Serial converters | |||||||
| GE Series 90 Driver | General Electric® SRTP | Series 90 PLC, RX3i PLC | X | ||||||||
| IEC 60870-5 Driver | IEC-60870-104 | RTUs & PLCs from various manufacturers | X | X | |||||||
| JSON/XML Driver | JSON | JSON Compliant Devices | X | Supports JSON retrieved over HTTP and HTTPS. Also supports XML. Read only. | |||||||
| Modbus Compatible Device | Modbus ASCII | Modbus ASCII Compliant Devices | X | X | X | X | X | ||||
| Modbus Compatible Device | Modbus PLUS | Modbus Plus Compliant Devices | Modbus Plus | Modbus PLUS requires additional interface hardware | |||||||
| Modbus Compatible Device | Modbus RTU | Modbus RTU Compliant Devices | X | X | X | X | X | ||||
| Modbus Compatible Device | Open Modbus/TCP | Open Modbus/TCP Compliant Devices | X | X | X | X | X | x | X | ||
| Motorola ACE RTU | Motorola® Ace Gateway API | Moscad RTU Family, ACE Family | X | Requires MDLC IP Gateway | |||||||
| NMEA 0183 Driver | NMEA 0183 | Serial GPS | X | X | X | X | Can function as both talker and listener | ||||
| Omron FINS Driver | Omron® FINS | CS Series PLC, CJ Series PLC | X | ||||||||
| Omron Host Link PLC | Omron® Hostlink | C Series PLC, CS Series PLC, CJ Series PLC | X | X | X | X | |||||
| OPC Client | OPC® Client | OPC Servers for various Products | OPC | Supports hundreds of 3rd party OPC servers | |||||||
| Siemens S7 PLC | Siemens® ISO over TCP | S7 Series PLCs | X | ||||||||
| SNMP Managed Device | Simple Network Management Protocol (SNMP)® | Standardized protocol for thousands of devices | X | ||||||||
| SNMP Agent | SNMP V1 or V2 | Allows VTScada to supply data to a networked device | X | ||||||||
| SQL Data Query Driver | SQL Data Query (ODBC) | SQL Databases | ODBC | ||||||||
