Opto22 Driver Errors
Error code (Decimal) |
Error code (Hex) |
Meaning |
-2147024809 | 0x80070057 | One or more arguments are not valid |
-2147024882 | 0x8007000e | Failed to allocate necessary memory |
-2147024890 | 0x80070006 | Handle that is not valid |
-2147024891 | 0x80070005 | General access denied error |
-2147418113 | 0x8000ffff | Unexpected failure |
-2147467259 | 0x80004005 | Unspecified failure |
-2147467260 | 0x80004004 | Operation aborted |
-2147467261 | 0x80004003 | Pointer that is not valid |
-2147467262 | 0x80004002 | No such interface supported |
-2147467263 | 0x80004001 | Not implemented |
001 | 0x1 | Net server access error |
002 | 0x2 | Modem init error |
003 | 0x3 | Communications request denied |
004 | 0x4 | Communications link failed |
005 | 0x5 | Transmit fail |
006 | 0x6 | Unable to allocate buffer |
007 | 0x7 | Receive buffer FCS error |
008 | 0x8 | Receive buffer CRC error |
009 | 0x9 | Receive buffer read error |
010 | 0xa | Receive download NACK |
011 | 0xb | WR MBX error |
012 | 0xc | Not supported |
015 | 0xf | Error in trans Id |
016 | 0x10 | Error missing previous packet |
017 | 0x11 | Error block size did not match |
018 | 0x12 | Error block number did not match |
019 | 0x13 | Error out of sync |
020 | 0x14 | Receive NACK |
021 | 0x15 | Comm fail packets |
026 | 0x1a | Error char timeout |
027 | 0x1b | Maximum transaction timeout |
028 | 0x1c | Busy or wrong SCode |
029 | 0x1d | Message framing error |
030 | 0x1e | Slave address mismatch |
0 | 0x00 | No error |
42 | 0x2A | Comm channel unavailable |
43 | 0x2B | Bad write address |
32768 | 0x8000 | Service transmit timeout |
32769 | 0x8001 | Service receive timeout |
32770 | 0x8002 | Service socket timeout |
32771 | 0x8003 | XML create error |
32772 | 0x8004 | XML parse error |
32773 | 0x8005 | Invalid request error |
32774 | 0x8006 | Invalid datum address error |
32775 | 0x8007 | Command result error |
32776 | 0x8008 | Unknown Totalflow CPC error |
32777 | 0x8009 | Invalid license |
32784 | 0x8010 | License expired |
32785 | 0x8011 | Unknown license error |
