Optimize Your Configuration
Reading and storing a large amount of I/O process data can require significant computer resources, especially when you have multiple redundant servers. The following describes several ways that you can reduce bandwidth and network traffic on your system.
Poll rate:
Do not set your scan rates to poll more frequently than required. For example, if you need data only every five minutes, it would be a mistake to leave all scan intervals (or poll rates for those using the Polling driver) at the default value of 1 second. Reading data, saving to the Historian, and synchronizing those values across servers and workstations more often than necessary can cause a significant amount of network traffic for no useful purpose.
Historian deadbands:
Set within I/O tags (and legacy Analog Status tags). If values are changing by tiny amounts very quickly, a good deadband will filter the data so not every change is logged to disk. Every time a value is logged, it must also be copied to all of the redundant historians. But, use care not to set the deadband so large as to miss important data. The default is 1/4 of one percent of the scaled range.
SSD drives:
Faster disk writes mean that data is less likely to be queued up, waiting to be written to the hard drive. A large queue can slow the rest of the system.
Anti-virus configuration:
Most anti-virus programs want to read each file that is accessed before allowing another program to write to it. If VTScada is logging hundreds of data points per second, and the anti-virus software is trying to scan each individual file before it will allow the write, then they are unlikely to keep up, making it appear that VTScada is slow or even causing an out-of-memory error if the queue size becomes too large.
Trihedral recommends setting an exclusion so that the Data directory in the application folder is not scanned, either on demand or on full system scans. The full system scan is more of an issue because it will prevent file access while a file is being scanned, stopping writes temporarily.
Turn off folder indexing:
Trihedral also recommends that you use the Windows advanced options of the application's Data folder to turn off indexing, thereby speeding up writes.
