GE Series 90 Addressing
The input / output tags addressed under the GE Series 90 Driver use the addressing system in the following table. An assist dialog is provided to help you create these addresses.
Preface the address with the register or bit type to be used. The limits on any actual addresses will depend on the configuration of the system and type of CPU used.
| Address Format | Data Type |
| %I# | Discrete Inputs |
| %Q# | Discrete Outputs |
| %M# | Discrete Internals |
| %T# | Discrete Temporaries |
| %AI# | Analog Input |
| %AQ# | Analog Output |
| %R# | Registers |
| %W# | Words |
| %S# | Status Bits |
| %SA# | Status Bits |
| %SB# | Status Bits |
| %SC# | Status Bits |
In this table, # represents the register or bit number, starting at one. Note that addresses configured as outputs can also be read by input tags.
