AlarmPagerStatusTemplate
Template to be used for the status message of alarms sent to a pager by the Alarm Notification System.
Section: System
Default: AlarmPagerStatusTemplate = %S.
Parameter |
Meaning |
%A |
Area of the Alarm tag. |
%D |
Date of the alarm |
| %F | Full tag name |
| %H | Short tag name |
| %K | Station number (Part of every Polling driver, and Station type. Context tags used as site must be given a property named "Stn", in which the station number may be stored.) |
%M |
Alarm description |
%N |
New sentence for email and pager messages. |
| %O | Operator |
%P |
Priority of the alarm. |
| %S | Status of the alarm |
%T |
Time of the alarm |
%U |
Units of the Triggering tag. |
%V |
Alarm value (this is the value of the alarm trigger at the time that it triggered the alarm) |
%W |
Pause for ¼ second. Has no effect on email or pager messages. |
| %Z | Setpoint. |
Value (%V) and Setpoint (%Z) will use the labels corresponding to these values as stored in the record where applicable. If no labels can be found, the raw numbers will be used.
Alarm Message Templates - Look here for examples
