Service Command Line Reference
The following command line options are recognized:
USE OF THE LOCAL SYSTEM OR LOCAL SERVICE ACCOUNT IS STRONGLY DISCOURAGED.
| vts.exe /s=install |
Install VTScada as a service using the Windows® operating system account, "Local System". Reinstalls if previously installed. Permitted, but strongly discouraged. |
vts.exe /s=install[NT AUTHORITY\LocalService] |
Install VTScada as a service using the Windows account, "Local Service". Reinstalls if previously installed. Permitted, but strongly discouraged. |
| vts.exe /s=install[username][password] | Install VTScada as a service using an account of your choice. Reinstalls if previously installed. |
| vts.exe | Run VTScada as an application. (requires administrator privileges). Fails if the service is not stopped. |
| vts.exe /s=start | Run the VTScada service, installing it first if not present. |
| vts.exe /s=stop | Stops the service if it is running but leaves it installed. |
| vts.exe /s=uninstall | Uninstall the service. Will fail if the service is running. |
| vts.exe /s=disable | Disable the VTScada service, this leaves the service installed but prevents it from starting. |
| vts.exe /s=enable | Enable the VTScada service if it was previously disabled. This restores the ability to start the service. |
